Desktop Inkjet Printers
MG3600 False Paper Jam
Hi, I have a MG3600 printer. I keep getting the error that there is a paper jam. I have followed both of these directions: https://ugp01.c-ij.com/ij/webmanual/ErrorCode/MG3600%20series/EN/ERR/1303.html and https://ugp01.c-ij.com/ij/webmanual/ErrorCod...
mns6 by Apprentice
  • 13590 Views
  • 3 replies
  • 1 likes
Resolved! Gray line when scanning using the sheet feeder
Hello,For some time now, I've an issue with my scanner (Canon MX925) when I use the sheet feeder: a grey line appears on the scan.If I put my document directly on the glass to scan it, the result is perfect.Example: It happened overnight, with no sof...
Scan exemple
Fab117 by Apprentice
  • 2398 Views
Resolved! TR8520 Leave power on or off
I have a new TR 8520, do I leave it powered up all the time or shut it off overnight?  Its the old question about which way does the ink cartidges dry out faster. Also, if its powered off and a FAX comes in - will it turn itself on to receive the fax...
mikech by Apprentice
  • 2993 Views
  • 2 replies
Scan
 My MG2500 has worked fine until a couple of days ago. The printer works fine except for the scan/copy feature. My copies have come out with a blank gap in the middle. I've cleaned the glass and loaded the originials correctly...also cleaned print he...
Wayne5 by Apprentice
  • 1896 Views
  • 2 replies
tr8520 scan problem
when i scan a multi page document through the feeder it appears to scan each page but only the first page is showing up in the saved document. Ideas?
Pixma iP110 line spaceing in text mode
Hello. I have a iP110 printer. It's working fine. I'm using it as a text only printer with a unix system. The only issue is that in text mode it prints at 6 lines per inch. I'd like to print at 8 lines per inch. I tried PCL and Epson escape sequences...
GF3200 Printer
I put a generic ink in my printer. It will not print right. The color is faded just as little in places. How can I remove the ink and put the Canon ink in? Thank you.
