MG4250 Will only scan if set from PC
Elliot999
Hi, My printer scanner will not scan directly from the printer, it will only start scanning when directed from the PC. Not only is this annoying but it also means I can not scan more than one sheet at a time, so a 5 page document has 5 separate files each with one page on it. Can anyone help?
Thanks
1 REPLY 1
Stephen
Moderator
Moderator
Hello, Eliott999!
Welcome to The Canon Community, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market. The MG4250 is not sold or supported by Canon USA.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
Keeping the above in mind, so that the Community can help you better, they will need to know about the Computer Operating System you're using (Windows Vista/7/8/10 or macOS 10.x), as well as the way you connect to your printer (USB or networked via WiFi or Ethernet).
Thanks and have a great day!
Friends and Family
