Desktop Inkjet Printers
Prints only on prompt
When I send a document to print, new window opens wthe print preview and asks me to start printing. How can i send it to printer without the previewhigh heels porn movies
cokivowu by Apprentice
  • 1888 Views
need help printing on glossy photo paper
Hi! I have a pixma mg2500 printer and wanted to pint out some photos so I bought the 8.5x11 glossy photo paper. However, when I select the glossy photo paper and then the letter size it tells me it cannot print. Someone help because i've spent alot o...
ri1 by Apprentice
  • 11155 Views
  • 3 replies
Pixma mg6320 won’t power on
This printer won’t power on.I was in process of replacing cartridge. I took out the cartridge and closed the printer. In response to prompt, I stopped the pending job.After this, printer turned off and won’t power on.I’ve removed cable and replugged ...
Cetest83 by Apprentice
  • 5302 Views
  • 5 replies
Pixma MG5450S suddenly printing blanks
HiI have a MG5450S which has started printing entirely blank pages. Everything sounds OK as it if is printing but nothing is coming out on the paper. Have manually checked and replaced all the print cartridgesRebooted computer Restarted printerPerfor...
MG6821 PGBK Print Nozzle Problem
I have a one month new MG6821 printer. The printer works fine in the beginning, until today all black printouts have double lines. I ran print head clean and deep clean, doesn't help. I have also ran print nozzle check pattern, please see below photo...
hliang by Apprentice
  • 10529 Views
  • 4 replies
Canon G3200 Printer
I just bought the Canon G3200 printer. New out of the box. I set it all up and it prints great if all you want is colour. The black does not print at all. I have tried all the trouble shooting tricks but nothing has worked. Any one have a simular pro...
MG3600 False Paper Jam
Hi, I have a MG3600 printer. I keep getting the error that there is a paper jam. I have followed both of these directions: https://ugp01.c-ij.com/ij/webmanual/ErrorCode/MG3600%20series/EN/ERR/1303.html and https://ugp01.c-ij.com/ij/webmanual/ErrorCod...
mns6 by Apprentice
  • 13561 Views
  • 3 replies
  • 1 likes
Resolved! Gray line when scanning using the sheet feeder
Hello,For some time now, I've an issue with my scanner (Canon MX925) when I use the sheet feeder: a grey line appears on the scan.If I put my document directly on the glass to scan it, the result is perfect.Example: It happened overnight, with no sof...
Scan exemple
Fab117 by Apprentice
  • 2396 Views
