Desktop Inkjet Printers
Printer will not connect to network
I recently changed ISP's and my Pixma MX490 will not connect to the new WIFI network.   I followed all the instructions in the manual and it shows the name of my network on the screen but times out when I try to connect.  Numerous attempts have all f...
Cartridge Connection to Printhead Holder
One cartridge on my 922 is not being recognized. I can press the front of the cartridge down and make the sensors meet. I can see this is working as the light comes on. Releasing the pressure kills the connection. I tried taping it down and wedging s...
River by Apprentice
  • 3023 Views
MG7100 printing problems
If I print a document in the normal way, the print is very blurred. If I print the same text as a photograph it is perfect. Has anyone got any ideas or a solution, my hair is white enough already. Many thanks Sb
MG 7500 LINES IN PHOTOS
I JUST REPLACED ALL MY INK TANKS AND NOW MY MG7520 IS PRINTING LINES IN PHOTOS. IT WORKED FINE WITH CHEAP BRAND TANKS BUT NOT NOW THAT I SWITCHED BACK TO CANON. IM SURE ITS NOT THE TANKS BUT A WEIRD COINCIDENCE. i HAVE DONE DEEP CLEANING A FEW TIMES....
Printing in black only
How do I print in black only on my Pixma MG6150. I have a Mac OS on high Sierra version 10.13.1 ?The colours are always running out, but the black cartridges last a lot longer.
asg by Apprentice
  • 2555 Views
Resolved! error 5100
Just purchased a  MG 3520 and run  maybe 10 sheets of paper then  a paper jam, it appears I am looking at a 5100 error. removed the  jammed sheet and  it all came out but nothing  will fix the error code. I have owned many printers, none that have qu...
Alarm Lamp lit on MG5520
Good Evening, I have a Canon MG5520 printer.  While I was out of town, the Electric Company replaced my meter.  My printer has been off for well over a week.  I do have it plugged into a surge protector.  The surge protector is still working.  My pri...
KimT by Apprentice
  • 2540 Views
Resolved! Pixma 922 stuck in 2 sided mode
I have a Pixma 922 that is stuck in 2 sided mode.  I am able to change this for a single copy using "Printer setting", but it immediately reverts back to 2 sided. I have my original on the scanner surface, and hit the "copy" buttons on the right and ...
PIXMA MX 459 Error Code B200
Hello All I'm new to the group and have a questions some have probably seen a few times. I can't seem to locate info on it. My PIXMA MX459 has 2 brand new Canon cartridges in it as of this morning.  For the first time since owning this printer I rece...
