PIXMA TS5320 Stuck in Copy Mode
Any help here? I've tried everything found on the Internet from unplugging for a day to hitting the STOP button while the printer is booting up. All I want to do is print!
After few ink flush my printer show error 5B, How I can empty the waste thank and where are located, I can't find any videos on you tube related to this issue
I just purchased this printer used. When I opened the shipping box and removed the paper tray, I found this part in it. The printer is showing error code 5C20. Does anyone know where this part goes? part found in lower paper tray
I have a Canon G6020/G6010, and since it came out of the box, meaning since it was new, it has had some horizontal lines that seem to appear when the print head passes and the feeder pushes the sheet, causing overlap. This happens in standard quality...
I just took this printer out of the box and set it up. There is no back light on the display window. Had to use a flash light to read it. So I returned it to the seller immediately. I would say this is a really bad defect. I bought this model be...
Patrick, You helped a person back in 2023 with a problem with his G7020 printer printing in all red. I had the same problem and followed your advice. It solved my problem.3 years later in 2026. Thank you. Steve Thomas
hey is anyone else having issues with their ink carts? I bought some that say they are compatible but the printer says they don't work. like they both say canon on them but the numbers are different. so I have an old blk cart and the number is 281, t...
I have no idea how to fix the error code 5B00
If my subject line here is vague and mysterious, it's because I can find zero common thread between these problems besides possibly demonic spirit possession. I purchased a brand new Pixma after a month long battle with a used HP sent me to the compu...
Greetings,Just set up new TR 8620a.Does the front "Operation Panel" need to be in open position to allow printing?I would hope that it opens automatically but mine does not.Thanks!
Hello,I just purchased a MegaTank PIXMA G3290 and have been borderless printing on card stock cards. Most of the time it works great but about 25% of the time it messes up the print in the same way by offsetting the print by a half an inch. I've trie...
I bought a new Pixma TR4722 printer, after uploading the drivers I preceded to scan some items to send them in an email - all went well in both the auto feeder as well as items placed on the plate. Then I wanted to print some documents from my comput...
I have a PIXMA TR 8620a. It is asking for the Admin password. I can't find it. Where can I find it?
Hi!I'm getting strange results in my Nozzle Check test print. The black and grey rectangles around the letter describing the colors are blurry. And there is also thin banding on the BK coloured line. See first image.I've tried every cleaning program ...
I jsut ogt new cartridges and the printer is printing everything pink. The black is fine if I print black and white but everything in colour (including black) has a pink tinge. Have cleaned and checked the nozzles and checked the cartridges for pla...
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
