mg7170 error code 1403
how to slove this issues pls advice
I have a new TR 4520 printer. Is the output tray supposed to click and stay in a vertical position ? Mine just lays on top the paper tray such that it must be held upwards while loading paper into the paper tray.
I'm on a Mac running MacOS Catalina 10.15.5 and am wondering about color profiles for the IP7220. Should there be color profiles installed when the driver is installed? And if so, what are they named? vDoes anyone have a list? Also, should they be in...
I have a Multifunction Printer (Pixma TR8520). After scanning several sets of pages, and exiting the IJ Scan Utility, all the pages disappeared. They aren't where they usually are in my documents and I can't find them anywhere else. Did I do somethin...
Now it won't print at all
This cheaper PIXMA from WalMart willnot connect to my laptop. I finally got the printer to connect manually to my WiFi, but laptop won't connect. So still out of business. Who knew printers would be so hard to get during COVID??Anyone have recomme...
I have had my CP910 for a number of years. Recently a scratch started appearing on my photos after the complete printing. It always appears in the same place and it is a perfectly straight line. There is no scratch on the blank photo paper. I have sw...
I have tried repeatedly to contact support since my MG2522 printer up and died on me. I need to send it in for a replacement, but not only are all sites down for customer support, but even their phone contact support hard-line is down! Doesn't do muc...
This MX922 is a replacement for a previous Canon printer which had similar error codes that I couldn't correct and ended up trashing it. Now I have the same situation with this Canon and am thinking I need to switch manufacturers. When it works, it...
I have been successfuly using my MG3650 with Windows 10 for some time.I have recently made some erroneous(?) change to my system which has seen the Canon Quick Menu 'reverse-L' shape icon become truncated in the vertical arm..The top two icons in thi...
I am beyond frustrated with this printer and with Canon. There is no support past a year and there is no documentation to help with this issue. Does anyone know how to clean the Waste Ink Absorber pads in a PIXMA MX492? I have been struggling to fi...
Hello...support is NOT available so hoping someone has an idea how to figure out why my MX490 printer will NOT print since I upgraded my PC from Windows 7 to Windows 10. Nothing in the online manual for guidance. Any thoughts or comments appreciat...
I'm having a problem with lines going through my printouts, I have clean and deep cleaned, aligned the printer heads poped out the ink cartriges and re-inserted them and nothing has helped can anyone advise me what to do next please and thank you for...
Here's an apparently unsolvable problem with an ip7220 inkjet printer. It's operating on Windows 10 through an USB cable. When printing a series of photos, the printer signaled it was out of paper. I refilled the paper tray, after which the printer ...
On my MX922, I can perfectly print text in many color. However, when I copy that printout, it only picks up the color characters, and not the black characters.
| Subject | Author | Posted |
| 08-26-2026 11:26 AM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
