Resolved! TS8320 error code 1259
I have a 2 wk old TX8320 that stopped with error code 1259 and will not clear.Hooked up directly to MAC. HELP
My pixma ip 6600d will not print red. Can I recycle the printer or throw it out
When I try to copy, the printer will give me error code 2114 and ask me to load paper into the rear tray, even though the size is set to A4 and there is A4 paper in the front cassette. When I look at the copy menu to try and manually set the paper so...
Printing from an iMac, OS 10.13.6. My TS8020 has started to tell me it won't print because of Support Code 1000 - no paper in the rear tray. I don't use the tray very much, and there is no paper it it, and the access doors are both closed. I use the ...
I was having issues printing from my laptop (taking ages to print), so I thought I'd check if there's a firmware update for the printer, and there was - v1.100. I think it was upgrading from 1.04 if I remember correctly. Anyway, ever since (yesterday...
Have a Canon MX860 and the magenta will not print after several deep cleanings
Magenta shows full, but is not printing. All red areas print yellow. I tried cleaning, checking alignment. It is not printing at all. Suggestions???? This worked fine for several months, but no longer.
Help, what is this? Accidentally posted on the wrong group.
I am looking for help in getting our Canon PIXMA MX 450 printer set up wireless to our HP Laptop that does not have a CD drive in it. Thank you.
Having an issue with the G1000 printer. Solid black areas are printing in gray and black stripes. Other colors are doing it but not nearly as bad. I ran all of the system cleaning procedures. Nozzle check printout is perfect. I have been using inkjet...
I've just bought a TS6350. I have a problem - on 99% of the times when I print something I get an error message that it's out of paper. But it's not. Nor is there a paper jam. what should I do please? Also, after I print something the drawer (where ...
Hi there! I wanted to try this as one last ditch attempt to maybe save my printer before having to accept I may need a new one. I got this printer almost six years ago for college, used it a decent chunk the first year but not enough to justify movin...
I wish I could show a photo but I've got horizontal lines showing up in printed images. When I print the nozel check pattern the top line cyan is showing half dark half light. Please help!
This was the first time I used the printer since purchasing it. I was able to print out a four page document using the color ink cartridge. When I then went to print out another document using the black ink cartridge, the paper on the right side wil...
HiI have a Canon MG2120.I have tried to install the software and driver CD many times with everything installing correctly except for the scanner driver.I keep getting a error message saying "Code:5,156,61 Cannot scan for these reasons: -Scanner is t...
| Subject | Author | Posted |
| 08-24-2026 06:04 AM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
