Folded cards in MX922
David_Pavlich
Is there a way to print 5X7 folded cards in above printer?  Open dimension is 7X10.  Thanks!
David
6 REPLIES 6
jrhoffman75
http://www.redrivercatalog.com/8-tips-for-greeting-card-printing.html
Thanks, John...I ordered cards from Red River.  However I found out after the fact that the M922 will only handle 17-28 lb paper after I contacted Canon support.  I ordered 60 lb.  My mistake.  But I guess that's what I should expect from an $87 printer.
David
David_Pavlich
Well, after about 15 or so failures, I finally got it figured out.  Probably not the way Canon would have expected it, but I got it working.  All I could see was me telling my wife that I needed another printer.  Not good! 🙂
David
I'm trying to add additional greetings and signature to a preprinted greeting card on my MX922 printer. One card went through well but every one after that gets jammed in the rear feeder. Any suggestions?
Do you know the weight of the card paper? See Message 3 above.
I don't know the weight of the card paper. They're boxed Hallmark Christmas cards -- if that helps. I had an iP8720 on which I printed greeting cards in the past without a problem. I thought this would handle them as well.
