Pixma iP 7220 Printer
My Pixma iP7220 printer suddenly won't power up. It wasn't showing any signs it was having any performance issues. Power cord and outlet are both good. Any suggestions? Thanks.
I take a scan of say my **bleep**, it scans and is saved as a jpg. But when I scan a printout of my **bleep**, it scans and saves as a pdf. And both are scanned on the Auto mode of the IJ scan utility. I am using a windows 7 computer. How do I get...
I can only print in duplex mode now. Print test page only prints header.Any ideas?TIA
Hi, I'm having trouble with my PIXMA iX6820. I'm trying to print some documents that appear centered on my computer, but when my printer actually prints them, the documents come out off-centered. I noticed that my printer has these strange margins se...
When I try to print I get a message: "The ink absorber is almost full.Press OK to continue printing." Once I press OK the printer works.I searched eveywhere to find out where the absorber is on this model but cannont find any information.Does anyone ...
My parents Ended giving me their old printer because of an error they had. I was able to fix this error by fixing the sponge. (BTW. The error code was: 6A80). But soon the carriage ended getting stuck on the right side. Now it's stuck and its impossi...
I suspect this happened when my Mac updated to Mojave 10.14.3 When I print, the document prints in a very small portion of the page. If i increase the image size, just a tiny portion of the document prints in a larger size (the window doesnt' change...
Ink cartridges are in place correctly. I have cleaned the print heads and rollers. I cannot get the printer to print or copy. What else can I do?Thank you.
I've put my Pixma through numerous cleaning and deep cleaning cycles and, whenever I print a test page, they always look the same, with the same faint areas for black and streaks in the colors. I tried manually aligning the print heads, and this seem...
Hi,I have MG6820 printer and would like to disable the printer feature and the associated ink errors. I have not used the printer for a long while, only the scanner from time to time.Now I am getting the "Support Code 1660" which I can't clear out t...
I just scanned my **bleep** on my multi-function PIXMA MG2522 printer but can't find it. Where is it?
Help me get a window on my computer to click instructions to my printer like Scan or copy.Also I just can't figure out the instructions to link my iphone and printer. Or how to get iTunes loaded to my phone?????help!
I've cleaned and deep cleaned this cartridge (it's the large one, 250XL PGBK) but to no avail. When I print a test sheet all the colors show up except the large black one. I just replaced all the ink cartridges and the printer utility shows I have en...
Hi!I have a Canon MG3220 printer, which has worked beautifully with my MacBook for 8 years. Today, when I went to print, the printer said it was "offline". The power was on and it was hooked up to my computer via a Usb. Nothing seemed amiss. After lo...
I have an MX922 printer, and the scanner function does not work I can print from it but seems like the scanner is not available. Any help is appreciated.
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
