Desktop Inkjet Printers
TR8622 printer .
Help me get a window on my computer to click instructions to my printer like Scan or copy.Also I just can't figure out the instructions to link my iphone and printer.  Or how to get iTunes loaded to my phone?????help!
poodles by Apprentice
  • 1992 Views
Can't download Printer Driver
Hi!I have a Canon MG3220 printer, which has worked beautifully with my MacBook for 8 years. Today, when I went to print, the printer said it was "offline". The power was on and it was hooked up to my computer via a Usb. Nothing seemed amiss. After lo...
ruheenar by Apprentice
  • 4513 Views
  • 1 likes
Scanner problem
I have an MX922 printer, and the scanner function does not work I can print from it but seems like the scanner is not available.  Any help is appreciated.
MX922 will not print correctly
Hello, My Canon MX922 will not print black characters correctly (i.e., letters/numbers).  The colors print perfect.I have been through all of the Maintenance items, including Cleaning and Deep Cleaning several times.  I have replaced the printhead, a...
Crispy47 by Apprentice
  • 1411 Views
Can't print 4x6 cards
I have an MG6120 and running windows 10. When printing 4 x 6 cards from the rear tray the printer will feed the card partially through the printer without printing and a message indicates a paper jam. After several attempts the card will sometimes pr...
Jbertke by Contributor
  • 921 Views
  • 0 replies
Resolved! What printer is this pixma?
Hi there,I have an older Canon Pixma. It's an all in one, wireless, with two paper trays and an array of card slots. I've had it a while but not sure how long. I have it's serial number but cannot find which Pixma model it is or it's model number (is...
Pixma G-6020 setup
I am following the setup instructions for the Pixma G-6020. The screen for language selection appears, and I clicked OK. THen I get a screen that says: "Set to English?" and below it "Yes     <Cancel>"     There are no "Yes" or "cance" buttons on the...
HSECP620 by Apprentice
  • 6928 Views
  • 9 replies
  • 1 likes
Resolved! my Pixma G7020 is dead, I need a replacement
Hi, my Pixma G7020 is dead, no longer turns on, I had tried plug in another power outlet in another room, connected to another laptop, but still doesnot help.Can any technical support here help me replace it?I work from home, so I need this fix as so...
Ip7220 Prints everything except text
I have an ip7220 installed on my MacBook Air running High Sierra.  I used the Canon setup to download drivers and install printer.  I am using a wireless setup which I initially used a USB cable to do the setup. The printer prints everything except t...
Pixma MG 7520 error B203
Is there any way to approach this problem with a hard factory reset, as with some other models?  The issue lies with the fact that there is no reset button on this printer at all - everything is controlled via the touchscreen, and once that displays ...
