Desktop Inkjet Printers
PIXMA MG2522
I just bought this printer and am unable to get it to operate.  It came with a CD, but because I have a newer model Dell I do not have a CD drive.  I have tried downloading the drivers for the printer on line at the Canon site for this model, but am ...
GCapps by Apprentice
  • 1648 Views
Quicken & TR8620 Scanner Issues
Upgraded my desktop & printer to a Canon TR8620. When I scan receipts into quicken, the scanner scans, but when it should be saving the file into the transaction nothing happens. The screen box of where to add the receipt from stays on the screen and...
MX922 error code 1008
Almost everytime I try to print the error code 1008 shows up.   I remove the paper, fiddle with the guides and reinsert.   Sometimes this works, but usually I have to power off the printer, then when I turn it back on it will print for 2-3 pages, the...
MLarry by Apprentice
  • 9425 Views
  • 11 replies
New out of the box mp210 setup problems
I am following the easy set up instructions exactly. When I get to step six and turn the power on, the machine makes a loud mechanical noise like a muffled machine gun a mile away. The light never turns a solid green but continues to flash after the ...
Canon mx 922 code 6000
Help I have seen where people have posted this issue but I can not find if people have had a resolution. If anyone knows how to fix this issue please post. HELP.
SMITHKA by Apprentice
  • 23096 Views
  • 2 replies
  • 1 likes
IX6850 Curved PGBK Check Pattern
I had clogged my printerhead, and I cleaned it carefully.But afterwards the nozzle check pattern for pgbk was warped. I triead varius functions (cleaning, alignment etc) but nothing worked. Is it broke?I can still print photos on photopaper if i chos...
betager by Apprentice
  • 1476 Views
  • 2 replies
IP8750 PIXMA detected then undetected.
I've gone through the installation process with the online downloaded driver and the cd supplied by canon. I am getting the same result every time. The driver detects the printer and says wait for installation to complete. After around 5-10 minutes i...
Kerry11 by Apprentice
  • 1163 Views
Resolved! Bug in Version 16 of PIXMA MX920 driver for Mac
I have used Image Garden to print custom CD/DVD labels directly on the disc with my MX922.  After upgrading the printer driver to version 16 the print to disc function is broken.  When I select Print in image garden the disc print dialog is no longer...
jbreef by Contributor
  • 2969 Views
  • 4 replies
  • 1 likes
Resolved! Veeeery slow printing
Several weeks ago my wi-fi connected MG7720 printer began to print text documents from my Windows 10 PC veeeeeery slowly with long pauses between each pass of the print head.  All printer settings, wi-fi settings, and router settings appear to be fin...
WJG by Apprentice
  • 54357 Views
  • 6 replies
Resolved! Pixma MX870 not printing correctly
I have an Pixma MX870 that I've had for several years. I recently updated my OS to Windows 11 and now my printer is not printing correctly. The print data on my PC shows that it is printing but the printer spits out the page without actually printing...
Resolved! Printer error paper type
Need some help. Just got the G620 Printer and loving the print quality. The problem I'm having is when I go to lightroom and print a picture I set up the printer in the app for 4x6 and I put the 4x6 paper in the printer but when I go to print I get a...
chad2323 by Apprentice
  • 9377 Views
  • 2 replies
MX 922 Scanner Banding
This has been going on for quite a while, but I thought it was down to the printed matter I was scanning.There appears to be tiny lines running across whatever I scan, whether it's at 150. 300 or 600 dpi.Someone suggested it's a hardware problem - I ...
Resolved! print head for canon mg6120
i have removed and reseated the printhead. i am still getting theU052 error. i have restarted the printer, no help. i have had this printer for at least 3 years, it has worked great until today. i have not changed anything, anyone know what the probl...
isowimn by Apprentice
  • 1968 Views
How to take top off PIXMA MG2922 Printer?
Too whom it may concern,I recently got a pencil stuck in my paper area of my printer. I was able to get the pencil out although when I did one of the ribbons for the printer came undone. It turns out this ribbon connects to the power source. I tried ...
