12-08-2020 07:55 PM
Hello,
Can you please instruct me how to print using only black ink in Canon TS6320 Printer?
12-21-2020 03:23 PM
Hi gsahoo0621,
The PIXMA TS6320 will use color ink tanks to print colored text. Even if the grayscale option is checked in the printer driver, if the original text is in a color other than black, the PIXMA TS6320 will combine the cyan, magenta and yellow ink tanks together to make a composite black.
To use only the black ink tank, the original text must be black and the paper setting must be set to Plain Paper.
01-19-2021 07:15 PM
I have been trying for the past several hours to print on a 4 x 6" sheet with my new Color ImageCLASS NF641Cw to no avail.
Ugh! Is it possible?
slfb
