Desktop Inkjet Printers
Resetting the Fax Memory on MX310
Hi,I wondered if there is a way to clear the fax transmission log on this all-in-one printer.  Alternatively, is there a way to reset the printer to factory settings (and effectively erase all memory)?Thank you for your input.
Franklin by Apprentice
  • 2099 Views
  • 3 replies
MG6200 and Windows 11
Hi,I recently upgraded my laptop to Windows 11 and am not able to scan documents anymore.Printing works though.Can you let me know if there is a driver available to scan with Windows 11 ? Thank you
juliens by Apprentice
  • 18753 Views
TR8520 Paper sticks in the ADF
When trying to scan multiple pages in the ADF of a TR8520, I occasionally have some pages that stick together.  Therefore, if I have a total of 10 pages, sometimes one page will stick to another so that only 9 pages are actually scanned (two are fed ...
hickeytp by Apprentice
  • 1661 Views
MX882 scanner driver fail
Have used my MX882 printer for years, including the scanner.  Now I get a message saying I have no driver installed.  I installed the driver and the printer works fine with the computer.  However, I still get the same no driver message when I try to ...
Need help with Canon MG2220
Good Morning Support Section,I request support on my Canon MG22200 printer. It has stopped printing. I want to replace ink cartridges but the ink container won't move for me to be able to change cartridges. Plus I'm not sure what mode I should select...
Printer driver
I have a very old printer which is not online. Can I get a CD to load a print driver for my TR8600 series printer?
Types of paper you can use
I have a PIXMA MG3620 Is it possible to print on clear sticker paper, and what settings to use? I have not been successful with this. Regular labels are no problem.
MJJ by Contributor
  • 9804 Views
  • 7 replies
Resolved! no one can locate name of my Canon Printer
Serial  # ABYFXXXXX.  Does anyone know how to locate the model of canon printers?  I've tried several locations, with no helpful response so far.  Thanks.[Masked serial number per forum guidelines]
bethH by Apprentice
  • 6124 Views
  • 2 replies
Printer prints pink and black
Hi I have a Pixma G6020 printer. I have had it a year and I rarely use it. I was printing multiple pictures. About 25 or 30 pictures on regular paper. Everything was fine and then all of sudden it’s printing in pink and black. No blue no yellow. I cl...
Takes Paper But Does Not Print
Troubleshooting my printer fresh out the box. Set up the printer on my network through the app. Printed the test page no problem. Now I want to print a pdf on transparent paper 11x17 and the printer takes paper, then spits out the paper without print...
Jcc2820 by Apprentice
  • 2242 Views
  • 3 replies
