Print from iPod to Mx870 - iPod defaults to AirPrint. I downloaded your Canon print app -
As in above : Canon app will print from camera roll ok, but defaults to AirPrint when trying to print from web or email.
I have a MF4450 multifunction. My Wndows8 computer will not connect during the Scan function. Any suggestions?
For scanning I prefer to use Windows Fax and Scan rather than Canon's own scanning software. When I had Windows 7, I was able to add the scanning component of my multi-function MP990 to Control Panel (Devices and Printers) as a separate device. This ...
Canon MG6120 suddenly only produced completely black scans (overview and scanning process proceeded normally but resulting files were just solid BLACK); printer works fine. No change in operating system (had NOT updated to Maverick from Mtn Lion). ...
I have a MG 7150 printer. I am making a photo album but encountered a problem when I tried to print on my double-sided glossy paper. When I select any paper type, other than plain paper, the option for Duplex printing is 'greyed' out. I tried plain ...
My MX452 does not communicate with my computer running Explorer 11 and windows 7. All funcitions between computer and printer work, except for ink levels and online manual.
I had used the Canon Lide 30 as a scanner on previous versions on my old IMac. I now have a new desktop with OS X can need to try scanning with it. Any suggestions?
Hello, We are getting error "unable to install printer, the remote procedure call failed" attempting to install 2 Canon D1180 multi-function printers on a MS Server 2012. We have 2 print servers. Attempting to install the printer generates the sa...
i forgot to buy a color cartdrige and need to print in black
I received this good info from Canon support on 01/09/2013 re PIXMA MX882: The bigger black ink tank contains pigment based black ink. This ink provides dark and sharp black text on plain paper. The bigger black ink tank is used when the paper typ...
I just got a new computer running Windows 8.1. I have no problems printing and scanning using the Canon software on the new computer. I would like to add the new computer to the Scan Menu that appears on the printer. The only computer that appears on...
I have a Pixma MG 5320, when I attempt to print multiple photos within a single layout, they end of getting aligned in the middle and top of the page and are printed at a size smaller than the desired layout. I have found the resolution once previou...
The scan to file option puts black vertical lines on my documents but if I scan the book page to print, it will print without the lines. This makes no sense to me. My PIXMA 452 all-in-one is NEW, so what could be the problem?
I have just put a new print head in my MP360 printer plus new cartridges and it worked fine for a few prints but now it has error code B200 which it seems everyone is familiar with( I thought is was just me) Thanks to everyone on this forum for showi...
Please could you help me to fix this problem?
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
