01-04-2014 06:09 AM
i forgot to buy a color cartdrige and need to print in black
01-06-2014 11:08 AM
Hi avonbymelynda!
To have a better understanding of your issue, please let everyone know what model printer you are using and the operating system (Windows XP/Vista/7/8 or OS 10.X). That way, community will be able to assist you with suggestions appropriate for your product.
If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team by phone or email.
Thanks!
01-09-2014 03:24 PM
I wanted to take a few moments to explain how the inks work together and how you can change settings to reduce the amount of ink used. It is possible, since you've had the printer for a few years, that some changes have been made to the way the unit prints text. Please review the information below regarding the ink consumption and the steps we can take to reduce the ink usage.
The bigger black ink tank contains pigment based black ink. This ink provides dark and sharp black text on plain paper. The bigger black ink tank is used when the paper type is set to plain paper.
The smaller black ink tank is a dye based ink. This ink provides greater contrast when printing photographs.
The printer heats up the printhead to put ink on the paper. It uses ink to keep the printhead cool. If there is no ink in the ink tank, the printhead would overheat and become damaged.
This is why the printer will not print until an empty ink tank is replaced.
Each ink tank has its own purpose. You cannot switch to one when the other is empty. The cartridge would need to be replaced.
The PIXMA MX882 will use color ink tanks to print colored text. Even if the grayscale option is checked in the printer driver, if the original text is in a color other than black, the PIXMA MX882 will combine the cyan, magenta and yellow ink tanks together to make a composite black. This is why your color ink cartridges are still being used. Duplex printing also uses a combination of colors to create black, this is due to ink drying time between pages when printing in duplex mode.
To use only the Pigment Black or large black ink tank, the following settings must be used:
1. The original text must be black.
2. The paper setting must be set to Plain Paper.
3. The Duplex printing option must be disabled.
4. The Grayscale printing feature must be disabled.
