Desktop Inkjet Printers
MX922 Printer not printing black
Hey Canon community,I have a MX922 printer/scanner and it hasn't been able to print black ink. I replaced the ink cartridges, performed multiple cleanings, reinstalled the latest driver, and for some reason it still isn't printing. I reset the printe...
kc1019 by Apprentice
  • 3755 Views
  • 3 replies
Blue won't print, even with brand new ink cartridge
So I have a MG2920 inkjet printer that I bought back in 2015, which has always worked fine, but suddenly it's started having trouble printing blue.  At first the blue was streaky, but the ink was low in the cartridge so I went ahead and changed it ou...
bevitty by Apprentice
  • 12146 Views
TR 8520 not printing every 4th line
I have a TR 8520 and it is not printing every 4th line.  I have done all of the alignments and cleaning and deep cleaning... everything possible, and it continues to do this.  I have also changed each of the ink cartridges (true Canon ink cartridges)...
kunz by Apprentice
  • 2004 Views
How I could make scan work
I got Canon MX-492 and installed the latest firmware, drivers, and utility software. I could make print  and access to the embedded Web server  (EWS) work. However, I had to spend several days to make scan work.After doing the following steps, scan s...
Tonchan by Apprentice
  • 3267 Views
  • 2 replies
Pixma MG 6120
My Canon printer is giving me a "ink absorber pads are almost full".  Does anyone know if they can be replaced and how to do it?  I can't find information on this error code anywhere.
Printer prints faded/lined pages
Hello, I have noticed the printer has been printing faded pages for only certain documents, especially those with confidential information. I tried to print the same without confidential info and it works just fine. How do I fix this?
kl141 by Apprentice
  • 3362 Views
  • 2 replies
tr 4720 selection for IJ Network Scanner Selector EX
Had a canon MX922 and was using the IJ Scanner Selector EX software to scan from control panel. Replaced printer/scanner with TR4720 so do I need to download a different IJ Scanner selector EX in order to be able to select the TR 4720? When I pull up...
pmills by Apprentice
  • 2459 Views
My printer is not printing
I have a Canon TR4520 and when i send to print something to print.it receive the paper but then it will spit it back out then i guess it will try to take it back in but it will be not straight to take it back end. i tried to clean the rollers and res...
Resolved! CANON MG5720 OCR can't connect
 My CANON MG5720 OCR says it can't connect.  But my computer connect to the printer to scan and do other jobs, just not OCR.   I have both USB cable and WiFi connection to the printer and all works well except OCR.Here is the error message I get.  Is...
deac33 by Apprentice
  • 1211 Views
