Driver Download
In attempting to download and install drivers and software for my Pixma MG7520 to a Dell XPS13 notebook running on Windows 10, I received the error message "Can't create output file"
Hi, I'm facing this issue with my Canon IX6810, the pigment black is printing distorted, when it comes to lines it's distorted, blurry, and when it comes to images the same effect. I have printed a nozzle test and it shows bent and distorted lines. ...
I've had a lot of small problems with my MX 492 that I've fixed myself. Now it is doing some new things:shutting off by itself, not copying and not scanning. Downloaded new drivers several times. Now it copies. Still won't scan. I need to scan n...
With Cricut Design Space, print then cut, how do I make the paper print from the rear feed iinstead of from the bottom paper tray ?
I have two problems with my Canon TS9521C when using CRICUT.1. With cricut design space, print and cut, how do I make the paper/cardstock feed from the rear tray instead from the main tray?2. Also, with cricut design space, print and cut, why is it m...
Hello,My Canon Pixma G3260 prints blurry in a section of the page. the top part from left to right prints perfect. but a quarter down, the right side is blurry.reading from this forum i learned about optical encoder and i cleaned it.it made it less b...
My pixma mp560 printer shows "printer error B200" when I turn it on--will not print.
Canon should be ashamed for this issue. Just searching the problem it shows up on many different models of printer and the problem is always the same. Tech support will have you waste a ton of time performing the same text book procedures that they k...
I have a TR7020 and am trying to print from a wireless connection on a Mac. The printer doesn't print and when I check the status on the Mac it says to Load Paper but there is paper in the cassette. When I test the printer by doing a copy it finds ...
Have a TR8520 inkjet which I have used for several years. It will do a few pages duplex fine. But on a longer document, it will stall ( not jam), and then spit out a half printed page. Then it goes back as if to start over.I am trying to do 40+ ...
I can't get my rear paper feed to work correctly with my new computer. When I go to use the rear feed it still pulls paper from the tray. I know that the rear feed works correctly because I do not have this problem when I use my old computer. Is ther...
I just tried scanning 3 pages--twice. The first time manually and the second using the ADF. The manual process resulted in page 1 being upside down. The ADF produced page 1 sideways and the last two pages normal.I am using a new computer with the ...
I got this printer recently and it was amazing when I first purchased it. It said it was getting low on ink and the quality of the color was low so I switched the ink and now it is worse. It is printing streaks across the page and is grainy. I have t...
Hello,Can software be updated so my new Pixma G6020 will turn on automatically/wirelessly when I try to print from another room in my house, or my phone or cloud? My old Pixma did turn on automatically when it was off and I sent something to the pr...
I have an older MP470 inkjet printer/ scanner. I can no longer get it to scan. I assume the problem is incompatible upgrades. I am using mac OS High Sierra 10.13.6. the error I get when I try to open the scanner is:software for "%@" failed to run...
| Subject | Author | Posted |
| 09-21-2026 06:05 PM | ||
| 09-21-2026 05:20 PM | ||
| 09-21-2026 01:06 PM | ||
| 09-20-2026 05:36 PM | ||
| 08-23-2026 08:30 PM |
