Desktop Inkjet Printers
PIXMA G6020 won't print color
Hi ~ My canon G6000 won't print color.  Ive done cleanings and trying to do a print flush, it keeps telling me I don't have enough ink but the ink wells are filled to the top.  I have tried to change the print level counter, and it seems to work, it ...
moontime by Apprentice
  • 2655 Views
  • 6 replies
PIXMA G620 Gray, red, and magenta not printing
Hello there, I have been trying to print some pictures of flowers and there seems to be an issue with the the gray, red, and magenta colors. Attached are pictures from the printer tape, the print head test and the picture I am trying to print. I did ...
20210603_084912.JPG 20260420_110242.jpg 20260420_110131.jpg 20260420_110200.jpg
dianai40 by Apprentice
  • 617 Views
  • 2 replies
Resolved! PIXMA iX6850 Ink lights off and one flashing
Hi,  I have a canon pixima IX6850 and one of the ink cartridges light has turned off since yesterday (551M). 551 C is also flashing. I turned the printer off and checked it again today and now the 551 Y light is off too. I have ordered more ink but i...
PIXMA MG3100 series printer leaking ink
pixma mg3100 leaking ink. black cartridge only. canon cartridge. happened with last one as well. tried all the  cleaning option, finally bought a new cartridge ( not a cheap fix) Same deal . cartidge head has heavy coat of wet ink. stuck a paper towe...
elbowls by Apprentice
  • 523 Views
  • 2 replies
PIXMA G620, not showing in Print dialog
This morning my Canon stopped showing up in printer dialog in my programs. The system says the printer is working and it shows up when I search for it in the system dialog but I can't select it as default.  I downloaded the driver again and installed...
Resolved! PIXMA MG3620 will not print color
MacOS running Sequoia 16.7.5. The printer worked fine for a few years. Now it will not print color: when I print an image with color, the color parts are simply omitted and the black parts print. The color & B&W cartridges are in place and the web UI...
kd-canon by Apprentice
  • 1008 Views
  • 5 replies
Resolved! Canon Pixma MG3600 refuses to print,
My printer has given up,  I have no paper blockages, plenty of ink and the rpint job is being sent to the print queue,just have the message "print error on MG3600". KIt is using Windows OS and connected via wifi. Should I reinstall the software ?  He...
Gilly1 by Apprentice
  • 3533 Views
  • 4 replies
PIXMA TR8620 error code 6800 solution
Hello community, after looking online after getting this error code, I saw that, just answer was giving false information, cannon only says you need a repair or new unit, and the unit gets stuck in this boot loop error code so you can’t reset in any ...
