PIXMA TR4722 printer goes to pause and ejects paper
RBH
1 REPLY 1
DerrickL
Possible Causes for TR4722 Printer Issues
Paper Jam
  • Stuck Paper: Check for any paper that may be jammed inside the printer. Even small pieces can cause issues.
  • Incorrect Paper Loading: Ensure that the paper is loaded correctly in the tray.
Sensor Malfunction
  • Misaligned Sensors: The printer may be detecting a paper jam due to a malfunctioning sensor. This can happen if the sensor lever is stuck or bent.
  • Physical Inspection: You can check the sensor by looking for it near the paper feed tray. Use a flashlight to see if it is obstructed or misaligned.
Troubleshooting Steps
  1. Inspect for Paper: Open the printer and carefully remove any visible paper jams.
  2. Check the Sensors:
    • Locate the sensor near the feed rollers.
    • Ensure it is straight and not obstructed.
  3. Reset the Printer: Turn off the printer, wait a moment, and then turn it back on to see if the issue resolves.
Additional Tips
  • Manual Feed Test: Try manually feeding a piece of card into the printer to see if it clears the error.
  • Pause and Resume Printing: If the printer is paused, go to the print queue and resume printing after checking for jams.
