PIXMA G620 Gray, red, and magenta not printing
dianai40
Hello there, I have been trying to print some pictures of flowers and there seems to be an issue with the the gray, red, and magenta colors. Attached are pictures from the printer tape, the print head test and the picture I am trying to print. I did a regular head clean, and then a deep head clean and nothing has changed in the colors. Not sure what to doPicture trying to printPicture trying to printWhat picture printedWhat picture printedInk RibbonInk RibbonHead test print after regular clean on right and deep clean on left.Head test print after regular clean on right and deep clean on left.
2 REPLIES 2
Stephen
Moderator
Moderator
Hello!
I’m sorry to hear that you’re having trouble with your printer. To help the community assist you better, we need a bit more information:
- Please verify the exact model of your printer? (It can usually be found on the top or front of the unit.)
- Are you seeing any error messages?
- Which version of Windows or macOS are you using?
- How do you connect to your printer: via USB or Wi-Fi?
Any additional details you provide will help the community better understand your issue.
If you are in the United States and need urgent support, please click HERE to visit your My Canon Account for personalized support options.
If you are outside the USA, please click HERE to find support options for your country.
Thank you, and have a great day!
DerrickL
Your printer is not printing magenta during the deep cleaning. Try a nozzle check to see what that shows. If any color is still off, then I suggest you do an ink flush procedure, it removes bubbles in the tubes and gets the ink flowing again. Just so you know, it does take quite a bit of ink to do this.  Here is the procedure:
https://support.usa.canon.com/kb/s/article/ART179437
