Turn off double sided scanning Canon 7270
Can't figure out how to turn off double sided scanning on a Canon 7270. I would like to turn it off by default.
I would like to know if anyone has had experience using a Canon printer (MX series) with a U.S. electrical plug overseas with a 220v 60 cycles receptacle. The rating on the printer says: 110-240v, 50-60Hz and .94A. Thank you in advance for sharing yo...
I keep getting the message 'Ink absorber almost full'. How do I put this problem right? Many thanks Jack
Hi,my scanner is a Canon CanoScan Lide 100; it was previously installed on a Windows XP SP3 32 bit, driver was lide100win1403ea24.exe, and I could access the scanner through the native interface of the driver, rich of options and parameters to be set...
I just purchased an ink refill kit for HP Photosmart C410, using the HP 564 cartridge. The printer is giving me problems and I am inclined to purchase a Canon inkjet printer. Can I use this ink in a Canon product?
I have not had problems with my Canon MX890 wireless printer until today. I had a new modem installed and my internet connection now works perfectly, but in the process I loss connection to my printer and I want to know how to reconnect our 4 laptops...
I am connecting to the pc via a usb. I am using windows 7.
I have an MX870 and will not be using it for some time -- months at least. Of course I will turn it off and pull the power plug, What else should I do? (I still have the wrappings from when I opened the box.)
VERY frustrated. Installed Yosemite 10.10 via iMac Software Update about 5 days ago. Guess I shouldn't have, because a few days later, my PIXMA MP450 suddenly stopped working. I got a screen message saying printer is offline, even though all cords (c...
Are there any US sources for a Ip5000 print head?
I replaced my now defunct HP Windows 7 computer with an HP ENVY Windows 8.1 computer. During the setup of my new computer, it found driver, but that driver had limited scanning capability, i.e., it could not save scanned pages directly to PDF format...
Clear ink tank indicator displayed so replaced it with genuine PGI-9 clear tank per instructions and same problem plus new B300 error code. Figured must've been bad new tank so ordered another and same problems. Ran all clean and deep clean utiliti...
When we scan an image on an mp460 canon printer using windows 7 64 bit there is a white line that shows up at the bottom of the scanned image. the white line is not on the original picture just on the scan.the white line is about 4 pixels or so high...
can you down load the mp 250 to my new computer thank you
Incoming faxes are going straight to memory. I can't figure out how to print it out. I am low on black ink, so is that the problem? (I still can print in black, so I would think there was enough ink to print out this one fax.) What gives?
| Subject | Author | Posted |
| 08-26-2026 11:26 AM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
