06-24-2013 10:12 AM
How do I stop or change the setting on my printer so that it does NOT print double sided?
I have the 2 sided set to OFF and I see no wherreelse to change that setting.
06-27-2013 12:17 AM
Hi mexstep,
A common cause of the issue can be due either to the Print Side setting requiring adjusting, or confirming that single-sided printing is enabled in the printer driver for your operating system. Depending on your OS and version, the setting may be found on the Finishing tab of the driver in Windows, or, as a radio button or under Print Style in the Basic drop-down menu of the Print dialog box in the Mac OS.
To review how to check the Print Side setting and if Print Side Priority is set, click here. Once reaching the FAQ area you can access the Article, "Selecting the Print Side (MF4890dw/MF4880dw Only)" by typing in the article name.
However, if further assistance is needed, please Contact Us.
03-04-2014 12:21 AM
I have my Windows PC and my MacBook (OS X 10.9.1) sitting here side by side, and I can find the Finishing Tab under Properties when printing from the PC, but I can find NOTHING when printing from my MacBook.
It is very annoying that all of my printouts from my MacBook are printed double-sided. Help!
03-09-2014 10:26 AM
Hi rwallaceking!
I know this issue is frustrating and I'm glad to assist you. To turn off two-sided printing on the Mac OS X operating system, please follow the steps below:
Before you print the document, we recommend saving this option as a "Preset", so that you don't have to make these changes in every application that you print from. To save this setting as a preset, follow the steps below:
I hope this information is helpful to you. Should you need further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666). Have a nice day.
03-09-2014 06:38 PM
Thank you. It worked!
