Ip5000 print head
Are there any US sources for a Ip5000 print head?
I replaced my now defunct HP Windows 7 computer with an HP ENVY Windows 8.1 computer. During the setup of my new computer, it found driver, but that driver had limited scanning capability, i.e., it could not save scanned pages directly to PDF format...
Clear ink tank indicator displayed so replaced it with genuine PGI-9 clear tank per instructions and same problem plus new B300 error code. Figured must've been bad new tank so ordered another and same problems. Ran all clean and deep clean utiliti...
When we scan an image on an mp460 canon printer using windows 7 64 bit there is a white line that shows up at the bottom of the scanned image. the white line is not on the original picture just on the scan.the white line is about 4 pixels or so high...
can you down load the mp 250 to my new computer thank you
Incoming faxes are going straight to memory. I can't figure out how to print it out. I am low on black ink, so is that the problem? (I still can print in black, so I would think there was enough ink to print out this one fax.) What gives?
I am looking for a printer that primarily prints photos. I am looking for one that can various sized photos, hopefully from wallet size, to bigger. Any suggestions would be greatly appreciated!
My Canon MX922 printer is one month old. I've only printed about five pages on it so far. I've recently been receiving a message when I start my printer that says "There is no document that can be forwarded". The printer automatically switches to ...
My boss often wants to copy multi-page documents using the ADF and copy mode. Since the feeder takes the pages from the top, the copies end up in reverse order. Is there any setting that would make the copies come out in the same order as the origina...
What Canon printers have pictbridge technology so I can print directly to it from my ELPH 130SI without going through a computer?
When I try and use my scanner I get the error report,"Cannot communicate with scanner, check that it is plugged in and truned on." When I go to Windows device manager I can see it and when I click on the properties buttonn it says that the device is ...
We loave our MG7120. It was previously set to scan to a laptop on our network. Now the only option is scan via USB. How can we reset it to scan directly to a laptop, and can it retain multiple laptops for selection when scanning is done by diferen...
I recently bought a new desktop PC with Windows 8.1 (64bit) OS installed. I thought it would be easy to set up my faithful Pixma MP800 - but NO! It seems that Canon doesn't like my printer anymore and refuses to provide a suitable driver to make it w...
The printer is about 4 years old. It was working well. Suddenly It showed a message saying the "wrong printer head". Then it stopped completely and will not switch on. What can I do?
| Subject | Author | Posted |
| 09-04-2026 06:47 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
