Desktop Inkjet Printers
MX922 ADF misalignment
HiIf I make a copy with the ADF the copy comes out shifted by about 1/4 of an inch. There is a line about 1/4 inch up from the bottom and the entire image is shifted up.Is there any kind of adjustment I can make? The printer is new.Thanks.
terryRI by Apprentice
  • 3452 Views
Resolved! How to set up printer without SETUP CD?
I  need to reinstall my Pixma MG6150 but the setup CD is broken. I have downloaded files for this printer (Win 7 Pro 32bit version). Is it just as simple as clicking on the driver file?I don't want to make matters worse! The reason for reinstalling i...
encyclia by Apprentice
  • 6250 Views
  • 2 replies
MX890 Error Message 5011 in printer window
MX 892 to be specific, Printer will not fully display normal menu....only error message (5011 in red bar abave the error note) that requires turning off and on then consulting the manual. I've turned off on several times, unplugged and attempted to d...
forgot password
Locked myself out of the printer settings how can I default the printer mg7520 back to the orig default settings so I can enter a new password.
Resolved! How check inkjet level on MG6320
I am trying to figure out how to check my inkjet levels on my Canon MG6320 directly on the printer window rather than having to go into the PC control panel and the utilities etc.  Is it possible?
Re: StartHtm MFC when installing Online Manual
Did anyone ever resolve this problem? I have windows 8.1 - 64bit I have the canon mx890 printer / scanner When I run the setup  software I get the error: starthtm mvc has stopped working It actually finishes running and I can print however I do not h...
Printer MX512 is printing double
Hi  My printer is printing slightly double like blurry and not ledgible. I have tried realignment but nothing has corrected this problem. If Anybody has had this problem please share any solutions, Thanks
Coriano by Apprentice
  • 3584 Views
Printing in B&W
I have a Canon MG3100 printer. I have no color ink in it, only black. I'm trying to print in B&W only but it won't print because there's the color ink is out. I've tried setting it to grayscale but it still won't print (even though I'm not trying to ...
spresco2 by Apprentice
  • 7327 Views
MX892 Won't turn on after error message B200
After reading all the post about MX892 and accompanying family of printers, I wanted to add my two cents on the MX892.  After a print job yesterday I received "error code B200".  after a search on Google and Canon sites and following instructions to ...
