11-19-2012 10:36 PM
LCD error code 5200 - what is it? how to fix it?
11-19-2012 11:13 PM
08-18-2014 08:44 PM
@1038 wrote:LCD error code 5200 - what is it? how to fix it?
I have the same problem with my printer... I need healp please, I use my printer a lot...
08-18-2014 11:04 PM
Hi!
To ensure the most accurate information is provided, we will need to know the printer model you are using.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/EmailCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks and have a great day!
01-22-2015 06:58 PM
Error code 5200 on MX432. I'm low on colored ink but don't need it. if I take the ink well out will it print in black ink?
I cant get out to get colored ink.
01-28-2015 08:42 AM
Hi micheleb,
Both ink cartridges will need to be installed in the printer in order to print, even if one of the ink cartridges is low or out of ink. You may be able to remove the 5200 error and continue printing by disabling the ink level detection function of the printer. To do this, please press and hold down the STOP/RESET or RESUME/CANCEL button on the printer for at least 7 seconds, then release it. You will need to do this procedure for each ink cartridge that is low or out of ink. Once the ink cartridges are replaced with Canon genuine ink cartridges, the ink level detection function of the printer will be re-enabled.
Hope this helps!
This didn't answer your question or issue? Please call or email us at one of the methods on the Contact Us page for further assistance.
