MP Navigator EX for my MX700 Printer Scanner.Can scan documents/photos etc. with MP Navigator, but I cannot save the files. Message says that my MP Navigator folder is write protected. If I change the folder that folder is listed as write prootected ...
I have a Pixma 870 printer/fax. I want to send a single fax to 3 recipients, none of whom I expect to ever fax to again. Like the fax machine at my office, I expected to be able to just put in the 3 recipients' fax numbers, perhaps separated by som...
YESTERDAY, I replaced the 3e Black ink cartridge and printed a photo. Soon there after I tried to print a spreadsheet and got blank pages. Tried to print a Testpage. It printed the Windows 7 logo, only, no text! The printer worked fine ealier in the ...
Error msg U052 after changing 225Bk cartridge. printed a couple of times then error message occurred
Hey everybodySo my printer is starting to make problems for some reason The problem is everytime i print picture, it coming out to much bright Althought when im printing a document/text file it turns out just fine..Someone can maybe help?Printer: Can...
Hello, I use to own a MX890 and use the MP Navigator software that came with it. I'd scan documents and the OCR pdfs worked great. Well that printer died and I replaced by the MX922. It does come with OCR but it converts it to a word pad document....
Hello.I used to have a Canon Pixma printer with a 35mm scanning facility built in to the lid. Broke down some time ago, unfortunately.And now Canon don't do Pixma printers with 35mm scanning.Been scouring the internet for an MG8250 or equivalent, wit...
I've just started using a Canon MX925. I've duplex scanned to my computer 2, 2-page documents (4 sides each) using the ADF. On one document, the final (4th) page extends the full height of the paper and is the right way up in the PDF. On the other, t...
I HAVE CLEANED THE GLASS AND IT DOESN'T FIX ANYTHING. OK, when I try to copy via the automatic feed, it starts out fine, but the more pages it prints I get a bar along the left side of the page about 1/2" wide that gets darker and darker until it is ...
I have been gifted with a Conon Pixma iP6000D printer and cannot find a print driver for Mac 10.8.5
On 7/27/2015 I posted a comment about the updated printer drivers for a Canon MX922 causing boot delays when the printer was not on when the computer booted. Boot times went from a normal 20 seconds to over 2 minutes. Instead of returning the next ...
Hello, About a year ago I bought a Canon MX450 printer & scanner, and I don't think it's ever worked properly. I usually have to reinstall the drivers every couple of uses, and the wi-fi feature has never worked properly so it's always connected to m...
Hello all, I'm getting a really strange error. I only started noticing this today. I have an 11 page document and when I load it in the tray, it scans all the pages, the status bar on my computer counts up to the 11 pages when it is scanning, but the...
| Subject | Author | Posted |
| 09-15-2026 11:48 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
