Desktop Inkjet Printers
iP3600 print problem
Printer won't print black (cartridge PGI-520BK) unless I implement print head cleaning operation of PGBK before printing every time.  All other colours print without problem. After cleaning, black prints OK for a short while, then needs cleaning agai...
sidb by Apprentice
  • 3205 Views
  • 0 replies
Canon pixma MG3200 misalignment.
Hi!Newby here!I want to print some labels and in order to make a test o a normal paper first i have print the format of the labels and after that i had try to print some squares inside the labels to see if they will match.The results are quite weird ...
inkcheck by Apprentice
  • 4492 Views
  • 0 replies
Printer wants user intervention
MG3222 printer wants "User Intervention" when tasked to print. Cannot find anything that tells me what "User Intervention" it needs. Had disconnected Win8 PC from printer, and connected it to Espson 310, then disconnected from Espaon, and reconnected...
MG6620 scanning directly to SD Card
  Just replaced my MG5420 with an "upgrade" to MG6620 after it got a 5100 error.  With the MG5420 I had an SD Card inserted and could scan documents to the SD card, then download via Wifi to my linux computers.  Can the MG6620 be configured to scan d...
I have a Pixma 6000D and a 64 bit with 8.1 OS.
 I need drivers for it. any suggestions?  I had it installed on this computer until this morning, when I foolishly removed the printer. It seemed corrupted after I installed another printer. Now I can't reinstall it, because the software is 32 bit an...
Yvonne2 by Apprentice
  • 3606 Views
  • 2 replies
Scan to Mac in OS X El Capitan
Is it still possible to scan an item to a Mac using the control panel on the printer (MG6320) when the computer is running El Capitan? If so, what utilities/drivers need to be downloaded? This used to work with the IJ Scan Utility, but I don't see it...
denn by Contributor
  • 23654 Views
  • 2 replies
canon i80 driver for windows 7 - 32bit
hi, I have canon i80 and using Windows 7 32-bit operating system.  I installed the drivers from http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/i_series/i80#DriversAndSoftware Both driver (File Name: aomwin110ea23us.exe) and sof...
yuvi4all by Apprentice
  • 4413 Views
