won't print wordpad
Have a pixma mg2120. Downloaded and installed new printer driver. Works fine and prints everything. Should work for any model printer.
The scanner on my multifunction printer (MF4350) stopped working after Windows 10 installation. Reinstalled drivers and still no luck. Finally called Canon support. They had me do the following, which seems to have worked: 1. In the Settings searc...
I have a Canon MX880 installed and running on USB. I want it to run on wireless but I cannot get it recognized. I am on a new Bell modem/router and CICS and passphrase are all correct (redone many times). My W7x64 OS will see the printer only when o...
Have just upgraded from MP 220 to MG 4250. Scanned images using the MP 220 sends them to MP Navigator file in Pictures Folder (Windows 8.1 - 64 bit) and I waswondering where scanned images using the MG 4250 were stored?
I am having some issues setting up my MX492 printer. I am getting stuck on the "Acquiring licenses" screen like some others. I turned off my firewall and anti-spam/virus software and deleted/reinstalled the setup software (probably not necessary) a...
PDF documents, each page is printed only partially. Tried to change printer settings, changed them to fit the page and etc., but printer still prints only part of the document. Should I get a diferent size printing paper? Is there a way to adjust the...
I have a MG7750 connected to an Asus RT-AC87U router and it will print a test print of around 6 characters but wont print anything else. It does this wirelessly, Im wondering whether the router is timing out mid cycle or something? Any ideas greatl...
If you're seeing all areas of black spreading on your printouts, I may have a solution. I just stumbled upon this:When printing to "US Letter " paper size, all black images and type look good.When printing to "US Letter Borderless" paper size, all bl...
Please explain the process for scanning multiple documents but creating ONE PDF file.
When trying to scan on PIXMA MG5722 I get message "set the PC to start scan". I can scan by initiating from PC but not from printer. Using iMac. Need to scan documents put on printer using the printer scan button. How do I fix this????
Where do I load photo paper for 4" x 6" prints on a Pixma MG5420? It speaks of an 'upper cassette' , which I can't locate.
My 'LOVED' MX870 was 'killed' by a neighbor when he was trying to assign for MAIN name shown on low part of computer where me ... and other neighbors ... clicked on opening and make changes; if needed.He ignored the MX870's assigned name ... and the ...
I can't scan with my Canon MX410. I'm told that I need a WIA driver. Where can I download one? I use Windows 10.
Getting - Txt cancelled. RX//fax mismatch when trying to fax. How do I disable function?
Recently I turned my Canon MG5320 printer on and a B200 error message popped up. It said "Printer error has occurred. Unplug the power cord and contact the service center." Is there a way I can fix this error message without taking my printer in to a...
| Subject | Author | Posted |
| 09-05-2026 10:28 AM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
