Printer Software & Networking
MF624Cw - wireless connection not working
Hello, MF624Cw has been working fine for past couple of years, then about 2 weeks its wireless connectivity seemed to stop working. I am able to print if I connect thru USB connection. When I checked the network setting, the 2 options (Select wired/w...
Canon IR3245 Not Discoverable on the Network
Hi all.I have the above printer assigned a static IPv4 address and ICMP ping tests work fine however the printer cannot be discovered by PCs on the network (same LAN).Configuring the printer manually on the PCs it fails to print. What am I doing wron...
Gurei by Apprentice
  • 4319 Views
  • 5 replies
Re: My new MG6800 printer won't print
I am having the same problem connecting with my Pro Pixma 100.  I followed the steps in a 2017 message last week and they worked but today, I get the same error message and the steps do not work this time.  Andy thoughts? Here is what I did based on ...
rdmegr by Apprentice
  • 5377 Views
Pixma MG6620 scanner error code
I have a new MacBook Pro with Max OS Big Sur Version 11.3.1. My printer/scanner is a Canon PIXMA MG6620. The printer shows up in my list of printers in System Preferences "Printer & Scanners" and I can print from my Mac to the printer. I've got the p...
KG6 by Apprentice
  • 2899 Views
  • 4 replies
PIXMA PRO-100 Wireless Connection Setup
Trying to install the never used Pro 100 to my wireless network.To do so I connected the printer via USB, however my computer never recognizes the printer.I tried connecting via an ethernet cable and it works. Is there a trick to get it to recognize ...
Tewigo by Apprentice
  • 3218 Views
  • 2 replies
