09-20-2017 02:10 PM
I recently purchased a MF634CDW direct from Canon for my home office. I set it up and seemed like all was OK, but my wife reported that the machine had an error message. I power cycled and then it seemed fine, but I now realize that whenever the device goes into sleep mode, and you send a print job, it displays an error message and you have to power cycle to get it to function again.
I am not using the wireless functionality and am using the wired network. Other then turning off the sleep mode altogether and accepting that this device has flaws, I don't have another option. I downloaded and installed the latest firmware but it did not fix the issue.
03-27-2019 11:47 AM
You say you fixed this. Would you please explain how? I suspect you actually meant to say you found a workaround. By suggesting you fixed the problem, you are giving Canon an excuse to avoid fixing their software.
03-27-2019 11:58 AM
09-21-2019 06:16 PM
This problem appears across all brands of Canon printers based on the complaints I've seen registered. From research I had done I learned there was a remote web interface to the printer. I had looked at a lot of things from the control panel to no avail.I wondered if I looked at the machine remotely while it was sleeping I might be able to figure out the problem. So I printed out the Network Configuration Page using the control panel. Then I went to the following URL (appropriate for my network YMMV).
//10.0.0.13/index.html. Two things happened: the Network Configuration home page came up and the printer started printing queued jobs. After much experimentation, it appears that the printer is only ignoring print requests after sleeping. So I went into my router's network configuration and added the printer with a reserved ip. I setup a destop icon with that URL and password protected the printer. I repeated that for other devices I own. Now I doubleclick on the wake up icon before printing. It's likely that the problem exists in third party hardware and software Canon buys. Why it hasn't been fixed is beyond me.
10-22-2019 11:10 AM
I have noticed that since I did my workaround by accessing the printer through the browser interface that my printer is no longer having a problem waking from sleep. The last few mornings I have started to print without first employing the workaround and the printer woke and ran the jobs. I am totally baffled.
10-22-2019 07:21 PM
When I send a job when the printer is asleep, I have to do these things... 1.) send the job 2). reach over and wake up the printer, 3.) (standup) & disconnect the usb connection cord, wait 30 seconds 4.) plug it back in & wait. It takes a few seconds, but it always works. It is just a huge frustration.
If I send the jobs, while the printer is turned off....when I turn on the printer, the jobs run fine. It is only when the printer goes to sleep.
10-22-2019 07:24 PM
What is a "workaround " - I am a tech dunce.
10-23-2019 05:42 PM
A workaround or kludge is a way to get something broken to work without actually fixing it. In this case, accessing the web interface to the printer in a browser to wake up the printer without having to reboot it.
10-23-2019 06:48 PM
"A workaround or kludge is a way to get something broken to work without actually fixing it. In this case, accessing the web interface to the printer in a browser to wake up the printer without having to reboot it."
No, that doesn't work with this printer.
04-29-2019 08:52 AM
I just setup this machine in one of our shops, imedialty saw similiar issue. The printer will go into sleep mode and disconnect from the wireless network. Sending a print job does not trigger the printer to wake up, and why would it?
Looking at the settings for the wireless setup, there is a an eco mode. I turned this off, and the printers wireless connection stays connected even if it has gone into sleep.
Problem solved for me.
04-30-2019 08:19 PM
