11-24-2024 01:21 PM
I just bought an imageCLASS MF654Cdw printer and have connected it to my network. When I send a job to print from my computer, it does not automatically wake up and print if it is in sleep mode. Instead, I have to go to the printer and manually wake it up, which is a pain. How can I get it to wake up when I send a job to print automatically?
11-24-2024 01:30 PM
Hello!
Please make sure you've installed the Canon software on your computer. First, go to our site here: https://canon.us/MF654Cdwsoftware
On that page, you'll need to verify/select your Operating System from the dropdown on the right, then tap the "Download" button to the right of the option that says "Master Setup." I've included a screenshot using Windows 11 as an example:
11-24-2024 01:35 PM
Hi Stephen, I have already successfully installed the software. This is happening after I have installed the software.
11-24-2024 01:40 PM
Since you already have the Canon software installed on your computer, I recommend contacting support for one-on-one troubleshooting so they can help determine why your printer isn't waking up as it should. Support is available Monday through Friday from 9 a.m. to 6 p.m. (ET) at 800-OK-CANON (800-652-2666).
11-24-2024 01:41 PM
Ok, thanks I will do that
11-26-2024 11:08 PM - edited 11-26-2024 11:11 PM
You do not say what operating system you are using, but try deleting the printer driver and reconnect it using the printer's IP address instead of allowing the driver setup to locate the printer on its own.
Edit: If that works, then set the printer's IP to "Static" in your router and in the printer's web Remote UI.
01-02-2025 08:16 AM
Thanks Captain obvious!
01-02-2025 08:16 AM
Any luck?
03-13-2025 11:51 PM
Same problem. If I touch the control panel on the printer, it wakes up and prints fine. But it will not wake up when my Mac sends it a document when it is asleep.
12-18-2025 11:56 AM
I have the same problem. Were u ever able to fix this? Such a pain! Canon can do better.
thanks
