PIXMA TS6420a: Paper Jam
For about 1 week, my printer constantly says there's a paper jammed. Every time I check, there's nothing jammed.Please tell me how to fix this. I have important memos to print asap.Thanks!!!
I have to say this product is a 50 dollar paper weight!! i cant get it to even go into factory setup! This is not the first cannon i have bought its about the 4th!! they all have mysteriously died after the first set of ink cartridge dies!!Im not eve...
This normally great printer is giving me trouble. I forget it's age but it's only printed 3800 pages. A test page showed that a couple of colors weren't printing. I did a cleaning, no better. Tried deep cleaning and got the 5200 error code. Turned th...
When ever I try to print a sheet of Avery labels, #8160, using template # 5160, the printer shifts my labels to the right. There are 3 columns of labels on a sheet and ea. column gets shifted to the right when printed. The first column on the left is...
Hello.PIXMA TR8520: printer head fails to auto-center itself upon raising cover. Also, receiving Support Codes 1405 and 520E. Any advice?
How do I scan multiple pages into a single PDF file with a Pixma TR8620a with my MAC using OS 10.15
I didn't use my printer for a Year, and i found out today that it displays P22 an the Orange Light won't seize to stop. I checked and found out after dismantling the printer that the Scanner Globe has a Crack. Is it Fixable? If Yes, where do i get it...
Hi. I have a TS5351i, I use it for work along with my circuit machine, I have tried multiple photo papers & setting for printing (photo card, glossy photo card etc) but no matter what setting I use or photo paper the ink doesn’t seem to be settin...
What does it mean when the printer says, "...unable to locate printer "CANONMG3260". Then it does not print. Everything seems to be in order, including the wifi (able to scan). I have reinstalled the printer on the mac... still showing the message ab...
Does anyone know how to change the Font size on Cannon G3270? TIA
I bought a Pixma TS3722 printer on 06/27/2024 and have beenunable to register it. When I put in my model TS3722, it says not found.Any ideas?
I recently purchased my 2nd Canon 3722 printer from Walmart. Printer worked fine for a few days. This is for myself, not a business.Starter black ink ran out - paid more for the cartridge than I did for the printer). However, I'm receiving an error 0...
Hello! Ive tried absolutely everything to print addresses on the flap and backside of an A7 envelope. The envelopes size is 5.25 inches height, and 7.25 inches width (yes, I measured). I have correctly loaded the paper in the feeder facing the righ...
Just got a Pixma TR8620a and have same problem with power cord. If I look at it the wrong way, it falls out. Incredibly poor product design by Canon.
| Subject | Author | Posted |
| 09-15-2026 11:48 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
