Desktop Inkjet Printers
Canon MG3200 Pixma is Printing Pictures Pink
Hello,    My problems are ONLY the printing of PICTURES, as the regular document printing is working fine.  I have checked the ink tanks numerous times, did all the tools  Cleaning, Deep Cleaning, Head alignment, Nozzle check, etc.  When I attempt to...
JdgDredd by Apprentice
  • 4645 Views
  • 2 replies
cannon mx 430 cannot install driver
Hi,I cannot install a driver to my printer.I have tryed manytimes with it seemingly to be a succesful install only to have a driver error pop up Do these printer just come to lifes end like this.It has wored flawlessly since the begining so i was won...
mp 600 skips lines
mp 600 alternately prints 4 lines and then skips 4 lines over and over again in a document when printing in black ink.
wiz by Contributor
  • 18012 Views
  • 18 replies
Ink/toner empty!
Hello,I just purchased a TS8151 printer. I have an older mac laptop with OS 10.6.8. I didn't find a driver for my Mac, so I connected to the printer via Google print. I'm able to print from my phone and ipad, but when I send to print from my laptop i...
alinamn by Apprentice
  • 2697 Views
How to remove output tray (front door) on MX922?
I bought the MX922 because I needed a printer under 18" deep, and the specs on the MX922 say it's 15.6" deep.  But when I print, the output tray (the door on the front) drops down, increasing the depth to something like 22".  In the tight space I hav...
CanonLaw by Contributor
  • 20941 Views
  • 10 replies
Mp drivers will not install for mx430 printer.
I recently did a system restore, and now I cannot install the mp drivers for my mx430 printer. I have tried installing from both the disc and from the canon website, and have also tried both wirelessly and using the USB connection. The printer is con...
MG3022 --can find where to scan
I am looking everywhere for where the scanner button is.  When I press the black or color button, it prints what is sitting on the scan bed instead of scanning it.  The whole reason why I bought this model was because it is supposed to scan. Can you ...
Canon IP1700 feed problem
I took the case off my IP1700 to clean the ink absorber, reassembled and reset the ink absorber message.  Now when I try to print a one page test document it will quickly feed one sheet of paper through and out of the printer then feed another sheet ...
Canon MX 432 Printer
What is wrong when I can't use the auto-document feeder on my printer? I get error stating "cannot scan from ADF" after loading paper into the document feeder and after depressing the start button.
hopeful1 by Apprentice
  • 2387 Views
  • 0 replies
MP180 Black inc warning - new cartridge
I have 2 new cartridges in my MP180. Color and black. I printed 2 pages out and now I get the black inc warning.  I tried reset it. I have tried to remove the cartridge and clean it and put it back. Nothing helped so far. What do I do?  Where can I g...
Dosferra by Apprentice
  • 2975 Views
  • 2 replies
