06-07-2015 08:22 PM
06-09-2015 09:20 AM
Hi BearsPaw,
The 'Canon MX922 Series Printer' icon is actually the icon that would be installed with our own drivers whether the printer is being used wirelessly or via USB. We actually recommend that the standard version (your current default) is the one that is used.
A 'WS' version of a printer is one that would sometimes be added by Windows through any automatic updates. This is part of the 'Web Services' platform that is used by newer versions of Windows, and in some cases may cause communication issues since this is not our own driver but rather one that is provided by Microsoft.
You can delete the XPS and WS versions if you wished to avoid confusion. If you do not plan on sending faxes from your computer at any point, you can also delete the Fax icon as well.
06-15-2015 04:25 PM
Yes, thank you for your answer. I searched all over the web, and looked through the manual but was still unable to find an answer to my question. This may be something that you wish to address in the future. I own two printers for my personal use, a Canon ImageClass mf4350 connected with ethernet and a Canon Pixma mx922. The Pixma mx922 is used via WiFi. I thought that the WS might have something to do with that. I cannot find the 'Accept as solution' button or I would click that. Thank you again.
12-05-2016 02:56 PM - edited 12-05-2016 02:59 PM
Answer says we can delete the "WS versions" and also the FAX "icon."
Does that mean only the WS icon, or the whole program?
It does not appear in the Windows Control Panel installed list.
12-07-2016 09:03 AM
Hi mikebove,
You can remove it from the Devices and Printers window in Control Panel.
Please note, when Windows performs another update, the WS icon may reappear.
12-26-2016 11:48 AM
