Desktop Inkjet Printers
broken Error code 1007
Ok,you guys need to fix this issue.Suddenly we are not able to print the same way we have been from our iphones ios 8.1.1.Suddenly the cannon mx922 decides we both need to fill "upper tray" and well,no,we do not want 4x6 or 5x7 print if a resume.sudd...
nickh by Apprentice
  • 7981 Views
  • 5 replies
Disable Device Info Sending on TS5320?
Here is another disable I cannot find in the on-printer menu of new TS5320 printer. I've read thru the on-line support - I find the other menu items listed (e.g. 'Key Repeat') but NOT -"Device info sending settingSelects whether you will send the pri...
JSardina by Apprentice
  • 1974 Views
  • 0 replies
Canon MX492 doesn't recognize paper
My wife was printing today and got a paper jam. I was able to remove all paper from it. I also cleaned the rollers 3 times. Now it always says that it is out of paper even when the tray is full. Any help will be appreciated. Thanks.
Jcromer by Apprentice
  • 2275 Views
  • 2 replies
Resolved! Cannot print on US postcards - TS5320
Just bought a TS5320 printer. Cannot get it to print on a standard US postcard, or a 3.5in. wide envelope. In both cases it says the wrong paper loaded. It always defaults to auto no mater what paper size and type I select in the printer setting usin...
  • 2948 Views
  • 2 replies
Color issue with the Canon MP-970 inkjet printer
I have a Canon MP-970 inkjet printer. Purchased around 2012, rarely used. For the past six months, the printer has not been used at all due to a temporary departure. Windows 10x64 system, USB connection. Seven cartridges, always used only Canon-brand...
gedonis by Contributor
  • 2391 Views
Pixma MG6620 power issue
My printer will turn on and the power light comes on but the screen is not showing anything and no bluetooth button lit. The trianguilar light, the one which looks like a lightning bolt, at the bottom right is also on and solid. Pushing of any button...
Help setting up new printer
I need help setting up a new Pixma 9160. I only got as far as installing ink! Printer won't recognise the PGBK: keeps giving error message. I've turned power off, and reinserted many times. I can't move on.Surely it is the right cartridge, it cam wit...
hannah1 by Apprentice
  • 1570 Views
MX395 - Very Weird Out of the Box
I bought a used/new MX395 - trying to do anything with it - downloaded latest driver for Win 7 and it's just not cooperating on ANY LEVEL. Paper feeder not being read, scan doesn't scan, ink levels are low but won't print - when I try to figure out t...
MG5750 will scan but only prints blank pages
Hi, so a few days ago I had to use the scanner on the printer for the first time, I am connected to via wireless network and had to go into the printer options and select the PC so it would save the scanned images on to my PC. Now when I try and prin...
tibs by Apprentice
  • 2591 Views
Slow Scanning Pixma MG4250
I have a Pixma MG4259 which I have used trouble free on a Windows 7 computer for some time, connected by cable as that computer was not WifFi enabled.I have recently switched it to a new Windows 10 computer and connected via WiFi. Printing works as i...
denison by Apprentice
  • 3215 Views
  • 2 replies
Resolved! MG3010 Scanning issue
My MG3010 has been scanning fine up until a couple of days ago. The problem was intermittent at first but has now become steady. When scanning, either with the IJ Scan Utility 2 OR with Scan Utility Lite, the resulting scan only shows the left 2/3's ...
baraka by Apprentice
  • 4395 Views
  • 5 replies
Printing shipping labels, MX432 has changed output
This is hard to describe, bear with me.  I print many shipping labels a day using 8 1/2 x 11 with 2 labels each. Until a few days ago when I wanted to print just one label, the printer would feedthe paper through and start the printing on the leading...
kittyAnn by Apprentice
  • 2815 Views
  • 2 replies
