Error Code 2800
jimmydelos2000
My printer keeps showig Error Code 2800 "The feeder cover is open. Close cover and select 'OK' "
To begin with, the feeder cover IS NOT OPENED! I have tried EVRYTHING!!! to no avail.  I have turned off the printer as well as unplugged it!!! Please HELP!!!!
I don't now what else to do!!!
2 REPLIES 2
Crista
Whiz
Hi jimmydelos2000!
Thanks for posting in the Canon Forums!
The Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback. Also for the community to assist you, what model printer do you own?
If you are in the United States and this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team. If the link does not work for you, you can reach them by calling 1-800-OK-CANON (1-800-652-2666), Monday to Friday from 10AM to 10PM ET.
If you live outside the United States, please click here and select your country or region for your support needs.
We hope this helps!
alaminsumon
I know this post is old, in case someone like me is looking for a solution to this problem here is how I solved it, I watched tons of videos but none of them solved the problem. I watched a disassembly video (https://youtu.be/DSuL8FD_JNY?si=j81Uvp9hS_cB4X8M) and disassembled the printer and found tiny broken pieces inside, not sure where it came from or probably it got in while moving around the printers, the plastic pieces were very tiny and in black color, Before I put the printer back into one piece I just tested by re connecting the cables (I only removed the top scanner portions. It started working and the code 2800 error is gone!!!
Hope this post will help some one
