I run Windows 11 Pro on a Dell Inspiron laptop. I recently got a PIXMA TR4720 printer/scanner/copier. The printer worked fine until I replaced the black ink cartridge; then things went bad. I'm enclosing links to the Alignment Sheet, the Nozzle Clean...
Hello everyone,I would like to ask whether other users of the Canon PIXMA MX925 are experiencing a similar issue with macOS Tahoe.Setup:Canon PIXMA MX925 (network printer/scanner)Mac miniConnected via LAN (same subnet)Scanning via Bonjour / “Scan → P...
My G7020 just updated its firmware to 1.080 and it will not scan or print over the network anymore. I've done literally everything in the way of troubleshooting including a factory reset and uninstalling all Canon software, but the new firmware remai...
How do you clear the B200 Support Code on my Printer? I can't do anything with the printer until the B200 code is removed and does not pop up as soon as I power up the printer. AND what causes the B200 code to be active all of a sudden?? My printer i...
Hi,Can I Fax from my PIXMA MX 922 using my cell phone? We have relocated and in the new location we have not installed a land line. In our previous location we had a land line and we had it connected to our printer. But since we don't have a land lin...
I have had this printer for 2 years and it suddenly won't scan. It prints fine. When I try to scan something, it will show the preview and when I hit scan, it always says, "Something went wrong. Please try again." What can I do to get it to scan ...
I set The ECO setting to OFF for double sided i went to the utilities on the app and got this message Safari can't open the page. The error was: "Navigation failed because the request was for an HTTP URL with HTTPS-Only enabled". i do not know what t...
Hello. I need some big help in determining why my Canon Pixma MG2522 is stopping a printing que mid print! If I may explain, I have the correct ink, zero paper jam, etc., and updated all drivers only to have this problem occur over and over. I bring ...
Canon MX922 Scan does not work on Win 11... I tried various options. No success
I'd only used this (excellent IMO) printer for B&W since I bought it. After 2-3 years I tried to print in color -- Nothing. It wouldn't print colors at all. I tried a few times to fix the problem, walking thru all the usual Maintenance steps Canon He...
Help! Can no longer print to Canon G7020 from my IMAC. I suspect it's related to the recent Mac OS update (Tahoe 26). I've tried everything including reloading drivers, confirming printer/computer/router all on same network, etc... Any guidance...
Hello and thank you. Can I scan slides using the Pixma MG 3620 printer/scanner? If so, how? Thanks again.
I'm using windows 11 on a Predator Triton 300 laptop. I have my PIXMA G7020 printer connected through wifi, so I can print any of my devices. Tried to print a document from my lap then my phone. The sound of the printer printing is there, NO INK on t...
My TS3722 print ran out of paper while printing now I am getting a error code of 7700 how do I fix this tried hard reset and still nothing
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
