Pixma G4210 fax problems
When I get incomming calls it goes right to fax tones like I am recieving a fax. What am I doing wrong?
I have a PIXMA MX860 and would like to upgrade my Mac OS to Sierra. Canon has no drivers listed for the PIXMA MX860. I currently am successfully using my printer with El Capitan. Does anyone know if I'll have all functionality on my printer - print, ...
HiI have just done a print of something and it printed the first bit ok but then something went wrong with the blue ink.I have scanned the paper and uploaded it to the net.
Is there any way to make them darker? Every printer I have owned in the past has the option to make copies lighter or darker.
I am an all Mac system in my house and I have my canon mx922 hooked up via usb to my mac mini. I am trying to print via my macbook pro but i cannot see the printer. Wireless LAN is enabled. When i go to add the cannon printer it doesn't even see it o...
What do these mean; Canon ip8700 series MP2, GL2, GL3, PT1, PT2 PT3, SG2/LU2, SG3/LU3. These all under printer profiles.The profile for my printer, PIXMA ip8720 is not listed. I've been using Canon IJ Color Printer Profile 2005 which I don't think is...
Hello,My MX920 just stopped scanning from the operation panel. I am using Windows 10.0.183.62. I am *usually* able to get the scanner to work from the Canon IJ Scan Utility, although it does not always work either. What happens: When I press the sc...
I can’t get past step 4 because the alarm light always blinks four times even before I installed ink and after I did . The tape and plastic thing have been removed . Should I just return it to the store.
Hello. I recently started having a problem with my Canon Pixma MG7140. Anything I print is never full-color, looks very glitchy and often isnt covering the whole page (appears in rectangular "chunks"). Here are a few examples: I tried replacing the i...
Can someone confirm the MG8120 printer is not compatible with Catalina? And if that is true when will it be? I can download the user manual, but my MACBook Pro does not recoginze the developer so I cannot open the file. What is the solution for th...
I had a pc for 20 years but now I switched to a mac. I downloaded the MG 2520 software to install it but I don't see scanner software. Can anybody help me please?
I am wondering if my scanner is incompatible with my computer operating system or if there is a software/driver update I need to install. Using the CanoScan 5.0 software the scanner will scan one photo, on attempting second scan it hangs, requiring ...
Hi, I am running Catalina 10.15.2 on my Mac and am having difficulties changing the print quality slider from NORMAL to DRAFT. Here are the steps I'm taking to attempt this: 1. in Safari I click PRINT from the FILE dropdown. 2. In the print window th...
Hello, I have a problem, with a very old (but still good in my opinion) Canon printer, IP4200. Recently it has stopped to print black. I've tried "cleaning" and "deep cleaning" options from the printer properties, but it didn't solved the issue. Al...
I own a PIXMA MX452 where I have been successfully scanning until just a few days ago. Now when I try to bring up the scanner utility, I am receiving error 'A scanner driver supporting this software is not installed. Install it and try again. (se...
| Subject | Author | Posted |
| 09-10-2026 04:51 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
