Desktop Inkjet Printers
MAC OS 10.15 Catalina Compatibility with MG8120
Can someone confirm the MG8120 printer is not compatible with Catalina?  And if that is true when will it be?  I can download the user manual, but my MACBook Pro does not recoginze the developer so I cannot open the file.  What is the solution for th...
miroho by Apprentice
  • 4975 Views
  • 6 replies
Resolved! CanoScan 8600F and Mac OS Sierra 10.12.4
I am wondering if my scanner is incompatible with my computer operating system or if there is a software/driver update I need to install.  Using the CanoScan 5.0 software the scanner will scan one photo, on attempting second scan it hangs, requiring ...
Difficulties Changing TS9020 Settings on Mac
Hi, I am running Catalina 10.15.2 on my Mac and am having difficulties changing the print quality slider from NORMAL to DRAFT. Here are the steps I'm taking to attempt this: 1. in Safari I click PRINT from the FILE dropdown. 2. In the print window th...
PIXMA iP4200 stopped printing black
Hello,   I have a problem, with a very old (but still good in my opinion) Canon printer, IP4200. Recently it has stopped to print black. I've tried "cleaning" and "deep cleaning" options from the printer properties, but it didn't solved the issue. Al...
frz by Apprentice
  • 5132 Views
  • 3 replies
Printing on discs on Canon MX922
I've had HP and EPSON. You could adjust both to cover the white on the discs. On the MX922 I set the disc covering to the max setting and still have white showing on the disc. Usually it's perfect on one side and a lot of white on the other side. I'v...
PPCer by Contributor
  • 2916 Views
  • 3 replies
Canon G2010 does not print Magenta Ink.
I've done Cleaning twice but it's not working. I keep avoiding the Deep Cleaning operation because it will make the ink overflowing and soon its service required technical support because the printer's ink pad is at the end of its service life.I need...
Resolved! Nagging ScanGear Message
When using Multi-PDF for export, ScanGear shows the message box: "Scan completed. You can continue scanning. Close the scanner driver to end." And the option: "Don't show this message again." But the message box appears again and again and again... e...
SMAAK by Apprentice
  • 3862 Views
  • 5 replies
Pixma MG7720 Borderless Printing Issue
Hi there. I have been unable to print at 8.5 x 11 borderless setting lately. I had no issue with this previously but it suddenly came up within the last week or so. I am on a Mac with OS High Sierra 10.13.6. I tried deleting the driver and reloading,...
Screen Shot 2020-02-19 at 8.44.28 PM.png Screen Shot 2020-02-19 at 8.58.19 PM.png IMG_3560.jpg
Resolved! Auto Duplex scan is not an option in IJ Utility - TR4522
Hi, I followed the instructions on how to scan double-sided but there is no "Auto Duplex" option in the drop down menu. The whole reason I purchased the printer is for scanning. It's quite cumbersome to manually do this with 1,000s of documents. Any ...
mjnd by Apprentice
  • 2933 Views
  • 2 replies
  • 1 likes
Resolved! MX882 Preview
MX882 Preview before printing unavailable, greyed out-unchecked. Need preview, how to get back?
48hccd9 by Apprentice
  • 3220 Views
  • 4 replies
Printer MX850 display screen is black.
Printer is great and in fine working order.  But, the screen is no longer lit up and so I can see any information about the menu settings.  Is there a light bulb that needs changing?  And if so, how do I do it?
