Desktop Inkjet Printers
TS6220 stopped connecting to laptop
When I try to connect I get a message 'Log in from your smart phone or tablet" But when I type the link into Google search it says no results. Scanning the QR code won't work either. Help!
Mo766 by Apprentice
  • 1473 Views
MP520 and Catalina
Hi, I have a MP520 printer.  Just got a new Mac laptop with Catalina (OS X 10.15).  Tried to add printer, it does recoginze the MP520 but then asks for software.  There is a short list of software from Espon, etc... nothing from Canon.  Apparently Ca...
mar10029 by Apprentice
  • 1659 Views
Question about PIXMA TS9500
Hi, I just got my Canon Pixma 9500 and I have a question about the trays.  First of all, what is the reason for 2 (front and rear) and how do I determine which one to use? Thanks
pslane1 by Contributor
  • 3579 Views
OpenPrinter Error on Start-up
Im trying to set up my printer with my laptop (Windows 10, v 10.0.18362) I've downloaded the driver package. When I try to execute the Print Head Alignment, i get an error "OpenPrinter Error". When I go through windows printer settings, it says "Driv...
aoibhell by Apprentice
  • 2838 Views
  • 3 replies
mx-532 paper blockage
I've had my the printer for some time with only an occasional paper jam which was soon fixed.Whenever I attempt to print,  the paper will move about an inch into the printer and stop. If I pull the sheet back out I see that the paper has some damage ...
ahaha by Apprentice
  • 1673 Views
Print both sides
I have a Pixma TS3122, which does not have 2-sided printing. However, I see that in Paper Handling one can choose Odd Only or Even Only, and that there is a Collate choice. So I figure you CAN print two-sided if you simply take the stack out and flip...
Pixma TR4520 error code 9500
Hello all. My first post !!     I cant seem to get any where on what an Error code 9500 means and what to do about it. this Pixma tr4520 was bought 2019 and has hardly been used which i wonder could  be a problem.  This printer itself starts up when ...
DMax1982 by Apprentice
  • 4574 Views
  • 2 replies
Cannon Pixma TS5120
When I make 2 sided copies in black, the print is light blue on both sides despite the original being in black & white. I put in a new black ink cartridge. I do not have trouble with single sided copies. Please help
Patski by Apprentice
  • 2012 Views
Resolved! TS6020 scanning problem
I'm on Mac OS 10.14.3 (Mojave). I have reinstalled both the regular drivers and the scan utility, and I keep getting the message '"A required file is missing or corrupted, or settings are incorrect. Try the installation again.' Is there any solution ...
dinorat1 by Apprentice
  • 12759 Views
  • 10 replies
Canon U Scan Utility
Can I use the Canon U Scan Utility with a MX432 printer? I bought a MX742 and the utility came with the new peinter.  Can I use the U Scan Utility with the older MX432?
ttbrogan by Apprentice
  • 36205 Views
  • 4 replies
MX922 will not power up
My faithful printer will not turn on today. The power button did illuminate the copy light briefly, then it lost power entirely. I've tried removing the power supply, using different power outlets--nothing seems to work. Do these printers just sudden...
medeab by Contributor
  • 5422 Views
  • 9 replies
Resolved! Pixma MX922 Support code 1403
Four year old printer with no problems.  I used it in the morning and it worked fine, later that day I tried to print and got Support Code 1403  "The type of print head is incorrect.  Install correct print head".  I've taken the print head in and out...
scporath by Apprentice
  • 5718 Views
