02-17-2019 04:05 PM
I'm on Mac OS 10.14.3 (Mojave). I have reinstalled both the regular drivers and the scan utility, and I keep getting the message '"A required file is missing or corrupted, or settings are incorrect. Try the installation again.' Is there any solution for this?
08-07-2020 01:08 PM
Hello.
Please install the latest CUPS Printer Driver, ICA Driver and IJ Scan Utility Ver 2.3.7. Once these files have been downloaded and installed, perform the following:
1. Click the Apple and choose System Preferences. Then open the Printer and Scanners menu.
2. Highlight and delete any copies of the Canon Printer listed on the left by clicking the minus (-) sign.
3. If the printer is being used via USB, disconnect the cable. Then wait a few seconds and reconnect. A new copy should appear.
4. If the printer is being used wirelessly, click the plus (+) sign and look for an option that says "Add printer or scanner". Click this option when you see it.
5. In the next window, click Default on the upper left corner. Wait a few moments, then highlight the Network version of the printer (with a set of numbers, or Canon IJ Network in parentheses).
6. Click Add on the bottom right corner when it becomes available.
Once this has been done, open the IJ Scan Utility program to test the scanner. The program can be found in the Canon Utilities folder in Applications.
02-20-2019 01:58 PM
Hi dinorat1,
Troubleshooting with our support group will be needed to narrow down the cause of your issues. Please contact our support group at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST(excluding holidays).
We look forward to hearing from you.
12-17-2019 11:51 PM
12-18-2019 04:09 PM
Hi baamende.
The upgrade to Catalena may have its own challenges for the TS6020. If the driver installation did not correct the problem, you will need to manually remove the old TS6000 series and Canon IJ Scanner drivers, then reinstall the latest drivers. If you're not certain how to do this, please contact our support group for help at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST(excluding holidays).
07-28-2020 09:48 AM
I'm on Catalina 10.15.5. My Canon TS6020 suddenly stopped scanning. I've removed and reinstalled the printer utility and updated the driver multiple times but still keep getting the error "A file is missing or corrupt, reinstall again". I can't tell you how frustrating this is.
08-07-2020 01:08 PM
Hello.
09-01-2020 11:42 AM
Yes, this works!
09-01-2020 11:43 AM
there is no accept as solution button
09-01-2020 11:46 AM
I took care of it for you .🙂
10-13-2020 11:21 AM
I also had a full day problem in upgrading my IJ Scan after downloading Catalina.
Thank goodness for representative "William" who, after long hold walked me through the entire process, I believe your problem maty be the same as mine . .
the driver page lists one download and two "optionals". They are NOT optional, you must download all three.
I hope this helps, if not, do try to get through to a representative, I have always found them so knowledgeable
Here is the link to the driver page: PIXMA MX922. or use whatever model you have.
