07-15-2026
09:13 PM
09:18 AM
I am having a problem with the Canon Quick Menu not opening (no errors or anything). I use it to change the settings for scanning mostly. The scan screen on the printer works, but I don't see any place on the printer to change the scan settings. I tried reinstalling Quick Menu and running as Administrator, but that did not help. I tried searching on here, but did not come up with anything useful. I am using Windows 10 Professional. Does anybody have any suggestions?
07-16-2026 12:45 PM
I mentioned that I could not open the Quick Menu and that I reinstalled it. I was able to solve the problem from what I read on here. The Event Viewer was mentioned, but I did not know how to get into it. After I found how to do that, I found the error for the Quick Menu executable (CNQMMAIN.EXE) under Windows logs\Application. The file that was causing a problem was a NVIDIA graphics file. I updated my graphic drivers and then Quick Menu was working again.
07-16-2026 01:30 AM
Are you opening the Main Menu of Quick Menu? It's the corner icon. It has the Scan options.
07-16-2026 08:48 AM
Try uninstalling the program, restarting your system, then reinstalling.
I would visit the support portal for my printer and ensure that I have the latest version of the canon quick menu installer that's available.
07-16-2026 12:45 PM
07-16-2026 05:12 PM
