PIxma IX6820
Unable to print to colored paper, such as blue, but switching to a white page it works.Is there a setting we need to adjust to print on colored paper stock!
I have anew TR150. For best ink consumption, should I leave it turned on all the time or turn it off after each printing to avoid the heads drying out? Some printers cycle some ink each time it is turned on. Wasteful. Does this printer do that?
My PIXMA MG6320 printer has a full ink absorber. Any tips other than buy a new printer?Thx...
New laptop, Win 10. Hooked up MG5220 with USB. Printer works fine. When I try to scan I get error saying scanner not on or not connected, Code 5, 156, or 69.
I bought a new PC, Windows 10, and it will not link to my MG6200 printer. PC says that I need the driver software installed. The new PC does not have a disc drive. I still have the original driver download disc. Tried to copy to a thumb drive to use ...
I am a Mac user. I upgraded to Catalina and the Scanner on my Printer says it needs an upgrade. I Downloaded an upgrade from the Canon Website but it didn't change anything....Am I doing something wrong? Does anyone have any suggestions? Thanks!
Need help to change scan format to pdf.Will the PIXMA MG3520 scan a document into a PDF? Presently set to jpg.
I have a Canon Tr 7520 prima printer. It is printing almost everything in green. I have changed all of the inks and it is still doing it Any help with this problem would be greatly appreciated.
My pixma mg3520 scan in jpg. Can this print/scan be changed to scan to pdf? If not, whats out here for purchase a inexpensive personal use printer/scanner that will scan to pdf?
My new Pixma TS8320 will not print all colors. Just yellow and black. It was printing all but once I changed the yellow cartridge it won't print other colors. Anyone else having a problem lke this?
Hello. Essentially, the paper ripped inside the printer - I could get some of it out the back cover but not all. So I took the screws out of the back and opened the printer up to get the paper out. In the midst of this, a black, plastic part on the...
I've had my printer about 2 weeks and I still have the initial ink cartridges that came with the printer in it. I don't use it everyday, but when I do all the colors bleed together. After a few pages they clear up so I made a test page to print the...
I have had my Pixma iP7220 for six years now and when I tried to print a photo yesterday, the printer would not turn on. I have tried the standard "unplug the printer from the wall and wait for so many minutes/hours, then replug" with no success. I h...
So I tried to print with the app, but some of the files and stuff were whitted out and I couldn’t press on them to print. How to fix this?
| Subject | Author | Posted |
| 09-05-2026 10:28 AM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
