Desktop Inkjet Printers
'Save As' 21 File fault
I use a Canon PIXMA MG5750 printer/scanner/copier and have a problem saving scanned images. In the 'Save Settings' I have set the  'Data Format' to JPEG/Exif but every scan I make is saved as '21 File' instead of 'JPEG'. I cannot open and edit the sc...
AlbaMale by Apprentice
  • 1743 Views
  • 3 replies
Resolved! MG 2525 Scanning Output size
Initially the output size in ScanGear Advanced tab was set to letter size 8.69" x 11.??",  but afterwards it auto changed to8.34" x 8.64,"  resulting in cropped preview image!!I've tried numerous hacks but can't change it back!!Please help.
progman by Contributor
  • 1985 Views
  • 3 replies
MG 5422 Printer Support Code 1681
My printer is not new - I have changed ink tanks many times over the years.  I am now getting this Support Code 1681 error.  The code would indicate I'm using the wrong ink tank.  I have replaced all tanks and still have the same error code.  The one...
MeDo2 by Contributor
  • 3367 Views
  • 3 replies
Scanning on platen - black angled line on edge
When I scan small documents (3"x5" for example) to pdf on the platen, the result shows a black line on the edge beyond the boundary of the original document. The line grows ever so slightly wider towards the end of the resulting image. If I scan an 8...
David121 by Contributor
  • 2474 Views
g7020 keeps printing the same page
My Canon Pixma G7020 keeps printing the same page.  This happened a few months ago and I got lucky and found a cure online I think by shuting the printer down and pressing some button several times but i cannot find those instruction.
jjjbdi by Apprentice
  • 2339 Views
  • 3 replies
MX 490
This printer has always worked with my Chromebook.  They are both using the same wifi network.  The printer shows up when I tell it to print, but nothing prints.  Used to work just fine.  I have deleted it, logged off and back on wifi with both devic...
Canon Pixma MX922 Not Printing Black
My Canon Pixma MX922 was printing just fine and I printed a bunch of worksheets out. I'm a homeschool teacher, so my printer gets used a fair bit. I was in the process of prepping work for the summer. During one set of worksheets, I ran out of ink. I...
Decreta by Apprentice
  • 2359 Views
iPhone app
I just succeeded in installing my 2 year old TR4520 with a wi-fi connection (failed when I purchased it). I was told in the instructions I need an app titled Canon PRINT from the spp store on my iPhone and iPad to print. If this is true, could someon...
jlyle58 by Apprentice
  • 7092 Views
  • 3 replies
Unable to edit scanned images
I get this error message when I try to open the jpg in HyperSnap, the editing software I use. Corrupt JPEG data: 117 extraneous bytes before marker 0xd9 I have never been unable to open a jpg image, ever. Just replaced my HP with Canon G3060 and have...
T_H_M by Contributor
  • 2779 Views
  • 3 replies
Support Code 6000
I keep getting the support code 6000 on my Pixma MX922 printer. It tells me to turn it off and remove the paper and cancel printing, there isn't any paper and I haaven't used the printer in months. Any ideas of what I can do to fix it?
Having trouble with my Pixma mx870 printer
Im trying to print somthing but my computer cant connect to my pixma870 printer it has a support code saying 300 the printer erly connected to your computer. I checked the wifi on my printer its ok but i dont know why it dont print. I called the tech...
Resolved! Can't get fax to work - always shows busy
I have a new Canon TR8620.  I can not get a fax to go through.  It seems as if it is not making the correct tone for the other fax to recognize as a fax.  One number I tried to dial is shared line.  I could hear the message but the fax didn't know to...
Resolved! mx 492 not printing color
My MX 492 printer is not printing color when I do a Nozzle check and when I try to print  a photo there is not color at all black or color help please
Jmason by Apprentice
  • 4179 Views
  • 4 replies
