Desktop Inkjet Printers
Resolved! Change Selphy 1300 default "paper type" for printing?
The Selphy CP1300's Windows driver circa 2020 defaults to some irrelevant settings for their KP-108IN (4x6 "postcard") supply pack. Besides needing to select "Japanese Postcard" when you want to print a simple 4x6 photo, you must manually change a de...
twalp by • Apprentice
  • 35588 Views
  • 9 replies
Printer will not print AOL emails
I have a MG7720 printer on my Windows 10 desktop that will not print AOL emails. The printer works fine and will print any other documents and photos on my computer. When I attempt to print an email it goes to the preview page and the preview never l...
tae111 by • Contributor
  • 2980 Views
PIXMA MG3620 Paper consistently jamming
Help before I lose the one brain cell that I have left after trying to fix this on my own! Till now, my PIXMA MG3620 has worked flawlessly. It was fine the last time I used it, then a couple of weeks later I had a document to print and the paper jamm...
Toadywot by • Apprentice
  • 1717 Views
  • 0 replies
PIXMA TR7520 Error Code 6004
Are there any reliable home printers in this world?I have had absolutely the most frustrating time with printers over the last several years. I have been through numerous printers and every single one ends up with issues that are not able to be resol...
get updates for removed printer
I run Windows 10 HOME 64bit.I had an Canon MP272 printer, but since I no longer used it, I removed (disconnected) it from the computer.Also removed Canon software. When I check for updates in Windows (Settings -> Check for updates -> Additional updat...
mgroen by • Apprentice
  • 754 Views
  • 0 replies
TR7520 will not print in draft mode on Mac
I bought a tr7520 so I didn't have to buy a multi clour ink cartridge when I am uning mosting one colour. Years ago I pixma printer that had the same multi cartridge feature and never had an issue with it. This new one will not let me select draft mo...
Canon TS3322
I have a Canon TS3322 printer and a fairly new MacBook Pro. My printer and laptop are in two separate rooms, so I need to be able to print using WiFi. I can't figure out how to do this. I can only print if I bring my laptop into the room with the pri...
Pixma MX432 - Always has problems grabbing paper
Hi All, I bought this thing about 2 years ago, ran out of ink about 18 months ago, and have not replaced the ink because this problem was so bad. Do others face the same issue? Is there a solution? I would say about 75% of the time it either would cl...
jmadero by • Apprentice
  • 23571 Views
  • 7 replies
Pixma MG7120 not recognizing ink
Hi,My Pixma MG7120 suddenly stopped recognizing the grey cartridge. It is not spent and I have primted with that cartridge before. It suddenly doesn't recognize it and I get code 1660. I have cleaned the cartridge area, which didn't seem very dirty. ...
Breasa by • Apprentice
  • 5903 Views
  • 4 replies
MX926 paper jams
Hi  A couple of issues: 1. I get paper jams which require removing the back cover and removing the jammed sheet, often once every print job. 2. messages to say that it is out of paper when there is paper in the tray. I find that it has lifted the fir...
Hugh99 by • Apprentice
  • 1719 Views
  • 0 replies
Cannot initiate scan from the Pixma MG7520
We had a power outage the other day and since then i can't initiate a scan from the printer to my computer.  i keep getting asked to identify the computer but it is not finding the one on the wireless.  i can print and initiate a scan from the comput...
abv by • Apprentice
  • 1845 Views
  • 2 replies
