Canon TS3322
jennifercs
I have a Canon TS3322 printer and a fairly new MacBook Pro. My printer and laptop are in two separate rooms, so I need to be able to print using WiFi. I can't figure out how to do this. I can only print if I bring my laptop into the room with the printer and use cords to connect the two. I've researched the web and found nothing that helps, so I'm hoping someone here knows! Thanks!
2 REPLIES 2
Moderator
Moderator
Hi, jennifercs!
So that the Community can help you better, we need to know exactly which version of macOS is running on your computer. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
Thanks for the tip!
macOS Big Sur
Version: 11.4
