Hi,For no reasons my Canon MG6820 start to add a left vertical black stripe when I scan. I try to clean the platen glass many times without positive result. I can't beleive that I need to replace my printer for which all the other function going well...
MX920 after a power fail started printing horizontal spaces between the actual content. Some content is missing on the edges of what being printed but the spaces are larger than the bit of missing content on the edges. Went through all cleaning, he...
My Canon TS9120 has stopped printing Word Documents. In fact it seems to have stopped printing anything but InDesign Documents. I just installed a new driver. Plenty of ink. I've cleaned the heads repeatedly. Do I need to replace it?
Hi! So I have the Pixma iP7220 and I need to print a CMYK InDesign file. But whenever I click on my printer and check the output it only allows for Composite Greyscale or RGB
i have A PIXMA IP8720. I have flashing white and amber lights, altenating....(white, yellow...white, yellow etc) 10 time each. printed this am fine, now flashing lights and wont print
Where do I find ICC download for my printer ?Canon IP8720
I have a PIXMA MP160 printer and a OS of Windows 10. What drivers do i download for my printer?
I don't use my printer often at all...but I did do a test 6 months ago when I had to reset my wireless capability and it worked fine. I just tried to print again and nothing at all is printing on the paper. I went through all the Maintenance Tests as...
I'm trying to download the driver for my MG2500 printer and during the printer connection section after an amount of time mid download the printer shuts off and causes me to restart the download. How can I make the printer stay on longer so I can be ...
I replaced the black ink cartridge in my MX492 printer and now it gives me a message " Check Ink 1686" and won't print.
When I turn on my ts6220 printer the 3 section operations panel will not come up. Only the initial word "HOME" shows. Though normally it would then display the operation panel options, but in this case it never changes from the word "HOME". I have ...
I have a TS9120 PIXMA. It has been trouble free until I tried to print and it said "no paper" which was correct. I added paper to the tray, and it then started with the Error Code Paper Jam problem. I have shaken it, opened it top and back multiple t...
I got this printer back in May and had no issues with it until recently. I typically leave it unplugged when I'm not using it. The other day I plugged it in and it won't power on. The power light comes on, but the display doesn't, I'm unable to print...
I did a transfer of my system to a new machine, but now my Canon TS9100 printer shows up as a USB disk in the system.It shows up in explorer and in disk manager - as a Removable USB, no media.Properties show "Canon TS9100 series USB device", location...
| Subject | Author | Posted |
| 09-05-2026 10:28 AM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
