Desktop Inkjet Printers
Band across image iP8720
My iP8720 had been working flawlessly but just started printing a band across the left side of the images, always in the same place. I've cleaned and aligned the print heads, tired different papers and images and the problem persists. Anyone have an ...
Pixma TR4520 prints exceeding slow
All of a sudden, for the past several print attempts, the printer is exceeding slow and takes minutes to print a normal page.  Print selection is either draft or normal, no difference in speed.  In addition, black n white or color, again no differenc...
Pixma TS3522 Scan Quality Poor
Hello, just wondering if there's any way to change scan settings? I just tried to scan a photo of my son and it looks like he's wearing make-up and his grey shirt just blends into the dark brown background. The lines are not clear, his coloring is ov...
Alilly by Apprentice
  • 1704 Views
MX490 Printing Blurry Avery Labels
I have a 3 year old Cannon MX490 that suddenly started printing blurry. Iʻve tried to correct the alignment, performed a deep cleaning, and updated the driver, and cleaned the film with a cotton ball. It prints regular information fine but the avery ...
nola808 by Apprentice
  • 1893 Views
Canon TS9100 support code 1240
Support code 1240 on my TS9100 says the panel is not open when it is in fact open.  No matter how many times I press the OK button and open and close the panel, it will not print and says the panel is not open when it is! Where are the sensors in thi...
bikejpmz by Apprentice
  • 1394 Views
PIXMA G6020 Alignment Issue?
I'm having an issue that I can't figure out. It seems that I'm having alignment issues but doing printhead alignment doesn't help. I've attached a couple photos to show what my problem is. I have only had the printer for a month and has otherwise bee...
TS6220 Can't print from rear paper tray
Have been using the PIXMA TS6220 for several months without issue for normal printing (documents printed on plain letter-size paper from the cassette).  Connected wirelessly to an HP Pavilion desktop running Windows 10 home. Am now trying to print la...
sarika by Apprentice
  • 22785 Views
  • 9 replies
  • 1 likes
My Canon MG2550S driving me nuts!
My printer has been working absolutely fine, then suddenly, the alarm lights next to the on button started flashing 10 times and when I had a look around,  a message said it needed to go to  be looked at/repaired. I've had it a couple of years now.Be...
Jfray by Apprentice
  • 1083 Views
  • 0 replies
PIXMA TS3520
purchased direct from Canon in Aprilprinter PIXMA TS3520Need black ink.  No one sells PG275 cartridge:  Staples, Office Depot, OfficeMax, LAINK, 1INK, INKJETS.COM,Tried to order from Canon.  Order won't go through, says "OUT OF STOCK"   Why don't you...
