Having trouble using MX922 Scanner, connected to Time Capsule via USB. Can Print, but not scan.
knpventura
I am using a new iMac, running OS X 10.9.1.  The Printer is connected directly to the time capsule via USB.  I can see the printer and confirmed printing works.
I downloaded and installed ScanGear and the Canon IJ Network tool.  The Network tool does not see the scanner.
Any suggestions?
Thanks,
Peter
2 REPLIES 2
Michael
Hello.
The unit will not be able to scan with a USB connection to a print server or Time Capsule.  The USB connection is only intended to be used directly with a compatible Windows or Mac OSX computer.
If you would like assistance with the wireless setup, please contact our support group using the link below.
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
Sort of my problem. The Printer prints on my Mac running Big Sur but scanner does not work. I get Canon MX920 series and then (84.ba.3b.0b.d5.26) Those last set of numbers are new to me and only appeared after scanner stopped being available,
