G620 printer media type for PT-101 Photo Paper
There's no Media Type listing for PT-101 photo paper for my new G620 printer. What listing should I use? Printer rejects Photo Paper Glossy II. Using a Mac.
I've downloaded the IJ Scan Utility Lite, but the option to scan double-sided in the ADF is not showing up in my menu as this online manual shows here: https://ij.manual.canon/ij/webmanual/ScanUtilityLite/M/3.1/EN/SUL/sul-009.htmlIs there a patch I n...
can i just use black ink i dont need color ink i have a pixma 2220
Here is what I'm suddenlu getting when I try to print on cd.Not only is there a color issue, there are lines across part of the cd.You can see it across the face and the Baer logo.The magenta ink is showing low but I don't thin changing it will solve...
My much loved MG5320 now has the dreaded B200 error. I've installed new ink cartridges, cleaned the print nozzles with water and alcohol and cleaned the print head with alcohol on a micro fiber cloth to no avail. HELP!
Can load driver for PIXMA MG3520 on new tower with Windows 11 and print test page. But can not print anything from the computer. Nothing goes into the "documents to be printed" How di I fix this?
CD Label printing off center. The printer is a MX922. Need help get it to center.
I have Canon MX920, I can print but scanning is no longer an option? I downloaded and installed the scanner driver already. This is a new computer, on my old computer I could scan with no problem. But now I can't seem to do it.
I am unable to make copies on this printer. It prints blank pages. However, I can print fine from my computer.Can anyone help ?Thank you
Have an MX492 that has been connected USB to a Windows 7 desktop. The computer has been replaced with a new Windows 10 desktop. When installing, it gets to the Printer Connection window, which shows Printer Detected. After a while, that changes to...
I did a bad thing and loaded sticker paper in the cassette that was too heavy! It fed in then started making an awful racket and whirling sound until it jammed. Now when I try to print it does not print and it returns blank paper out from the back! ...
My MX922 printer is not printing. I downloaded the printer driver from the Canon website and reinstalled. The printer has plenty of ink and it feeds the paper correctly. I printed a test page and the color bars look fine, but no cross hatch pattern o...
I just bought this printer it didn`t come with a cd I can`t find this printer on the canon setup page so i can't get the drivers and i`am unable to use it.Can anyone help what do i do
I have a Prixma MX922. I am trying to print a document from my Samsung S9 android. I have downloaded everything properly but continue using to get error code 1007 which has something to do with the paper. There are 2 trays but only 1 holds regular ...
Replaced TR8520 PGBK used cartridge with new cartridge. Printer display screen shows that it is a "used" cartridge and will not print using that cartridge.Solutions tried:Inserted new cartridgeUnplugged the printer and plugged it back inTried another...
| Subject | Author | Posted |
| 09-15-2026 11:48 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
